Difference felt with ITR clutch/flywheel?
What differences would I feel with an ITR clutch & flywheel in my otherwise pretty stock LS? It will bolt up with no problems, correct? I know rpms will build a little faster, anything else?? thanks!
I have looked into aftermarket....I just needed a clutch anyway and was thinkin about tryin to pick up a flywheel and clutch that might help some....but i figure there are no huge differences until you drop to the 9lb range of flywheels....so will probably just go stock clutch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arw321 »</TD></TR><TR><TD CLASS="quote">I think the biggest difference you'll find will be that your car will rev noticably quicker. The ITR flywheel is about 5lbs or so lighter than your stock LS flywheel.
Adam
It's only 3 pounds lighter. Stock is 18, ITR is 15.
I would personally go with the 12.5 pound or the 8.8 pound xAct wheel. I've got it and it rocks. The only thing wrong with it is it's too light.
I should have gotten the 8.8
Adam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Volcom »</TD></TR><TR><TD CLASS="quote">
I should have gotten the 8.8</TD></TR></TABLE>
I've heard as light as 14 lbs for ITR and as heavy as 19 for the stock LS flywheel, although I've never weighed them. Thanks for the clarification.
I should have gotten the 8.8</TD></TR></TABLE>I've heard as light as 14 lbs for ITR and as heavy as 19 for the stock LS flywheel, although I've never weighed them. Thanks for the clarification.
No problem man, that's what H-T is here for
