Where's the coolant bleed bolt?
Old Oct 27, 2003 | 08:28 AM
Rain_man's Avatar
New User
Default Where's the coolant bleed bolt?
I'm going to be changing the coolant, and realized can find the coolant bleed bolt on teh block. I'm not referring to the drain bolt, but the little nipple on the block that lets out bubbles. This is on a 2000 accord v6.
Thanks!
Old Oct 27, 2003 | 09:03 AM
Nick H's Avatar
New User
Default Re: Where's the coolant bleed bolt? (Rain_man)
you don't bleed coolant like that...you have to do it by leaving the radiator cap off and waiting for no more bubbles to appear while the car is turned on...and just keep adding coolant so that it doesn't get too low and make you do the process all over again...
Old Oct 27, 2003 | 09:04 AM
iam7head's Avatar
passenger side, kinda near the oil pan and right next to the axle
Old Oct 27, 2003 | 09:08 AM
Nick H's Avatar
New User
Default Re: Where's the coolant bleed bolt? (iam7head)
that's the drain i thought...not a bleeder...correct me if i'm wrong...
Old Oct 27, 2003 | 09:37 AM
iam7head's Avatar
Default Re: Where's the coolant bleed bolt? (Nick H)
oh..my bad
Old Oct 27, 2003 | 09:48 AM
Beach Accord's Avatar
on the thermostat housing i do believe.
Old Oct 30, 2003 | 08:37 AM
Rain_man's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H &raquo;</TD></TR><TR><TD CLASS="quote">you don't bleed coolant like that...you have to do it by leaving the radiator cap off and waiting for no more bubbles to appear while the car is turned on...and just keep adding coolant so that it doesn't get too low and make you do the process all over again...</TD></TR></TABLE>
I don't know how it's on Accords, but on my Integra, there was a bleed bolt on the block specifically for that.
Rain_man's Avatar
New User
Default Re: (Beach Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beach Accord &raquo;</TD></TR><TR><TD CLASS="quote">on the thermostat housing i do believe.</TD></TR></TABLE>
Thanks, I'm going to have a look...
Old Oct 31, 2003 | 03:48 AM
TouringAccord's Avatar
H-T Order of Merit
or close to it. Cant remember exactly but I know it was around there somewhere.
Old Oct 31, 2003 | 07:36 AM
88LXiProject's Avatar
Agreed. Right before the path where the coolant enters your block/head and goes around it. should be near and below your distributor. hope this helps.
whiteGSR
Jul 26, 2022 03:06 PM
Rvu
Jan 29, 2010 08:15 AM
MrViet
Oct 20, 2009 09:43 PM
tico
May 11, 2009 03:16 PM
mannyp4
Jul 9, 2007 09:21 AM
