what header for b16 (i searched)
i have a b16 first gen. and would like to know which year integra header i would need to purchase for it to fit on my motor. also, are there any headers from dc that already have the two o2 sensor bungs. if anyone has any suggestions as to which brand header would be good in a 300-400 dollar price range i would appreciate it.
Any B series header will fit... more than likely you'll have to weld in your bung. Also, the GSR and Type R teg headers are a bit taller than the DOHC VTEC Del Sol, and 99-00 Civic Si Header. So I'd go with a DC Sports Del Sol VTEC header.
Consider this...
I have a B16 in my CRX and have a one piece header. I have to do ALOT of work to remove the header. A two piece header would def. be easier to work with. Also, The Catyl. Conv is where the second O2 sensor can go.
BW
BW
you're saying i should go with the del sol vtec so that i dont scrape the hell out of the bottom of my header on the ground? if so that sounds like a good suggestion, what year del sol vtec?
i would usually take off my radiator to get to my stock exhaust manifold when replacing it anyway, what else would make the one peice a problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biglebowskicivic »</TD></TR><TR><TD CLASS="quote"> what year del sol vtec?</TD></TR></TABLE>
94
94
rexless_wreck
Dec 5, 2005 12:07 PM
HATCHingMN
May 21, 2004 03:53 PM
