D16Z6 with D16y8 manifold?
Old Oct 26, 2003 | 10:07 PM
Tw1n Turb0 Z's Avatar
Default D16Z6 with D16y8 manifold?
Guys
The SOHC is going into my 89 CRX Si in a week or two and a friend is offering to sell me his y8 manifold for pretty cheap. He is trying to convince me it flows quite a bit more/more power/etc but is it really worth it?
Old Oct 26, 2003 | 11:17 PM
1CiViC1's Avatar
Default Re: D16Z6 with D16y8 manifold? (Tw1n Turb0 Z)
what exactly is "pretty cheap"?
Old Oct 27, 2003 | 12:11 AM
91civicDXdude's Avatar
here are my thoughts on the y8 manifold..
at a first glance, you will notice the HUGE bulbous plenum, absent on the z6. upon closer inspection, in addition to the plenum being wider, the runners come out the back instead of directly 90 degrees down like on a z6, meaning it has longer runners.. longer runners + bigger plenum = ? it sounds like a manifold designed to try and flow better than previous ones, although short runners and big plenum is actually type r characteristics.
Then, i think about this... the Y8 has more advanced ECU tuning, better intake manifold, a stock 4-2-1 header, and it only makes 2 more hp?
I'd like to see some dyno graphs comparing the two.. (note the VTEC crossover differnces in z6/y8...)
Old Oct 27, 2003 | 03:08 AM
USDM 4G VTEC's Avatar
i did the swap abou t 3 weeks ago
IMO its worthed and u can actually feel a diff on trotle response since theres more volume of air available.. and its more felt on both low and bc of more air and top end bc of more air flow...
heres a few pic for you to look at..
compare the Z6 and the Y8 manifolds.....
heres the Z6 manifold
the Y8 manifold
and the final result
Old Oct 27, 2003 | 04:59 AM
IntegraXSi's Avatar
Most of that was done to beat emission standards. I have never seen a syno on this but I have been told that a Y8 running OBD0/1 Setups make more hp than a z6
Old Oct 27, 2003 | 05:07 AM
Bontke's Avatar
Default Re: (IntegraXSi)
LOnger runners will result in a more broad power bnand and torque at lower RPM.
Old Oct 27, 2003 | 05:08 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
posted by eg6ajk - here
http://www.hadamotorsport.com/...x.htm
lots of dyno graphs...hard to tell if z6/y8 manifold differences are exactly correct because of tests being done months apart. interesting though!
i believe in general...
longer runners make more low/mid rpm torque and power.
shorter runners make more high rpm power.
Old Oct 27, 2003 | 09:30 AM
JenniferDC5's Avatar
the y8 manifold is bigger
Old Oct 27, 2003 | 12:40 PM
Default Re: D16Z6 with D16y8 manifold? (JenniferEF9)
Cheap is 25 bucks
So I can run an OBD 0 on this and TPS will be cool?
Old Oct 27, 2003 | 12:41 PM
IntegraXSi's Avatar
Yeah thats a good deal.. Just make sure you get the 5sp mani and not the Auto.....
Old Oct 27, 2003 | 12:44 PM
Yep, its off a 5 speed
Im just trying to go as CHEAP as possible.
I got a 100k D16Z6 COMPLETE swap w/neuspeed bushings on the linkage, MSD ignition, chikara header, and some other misc stuff all for 300 bucks
I am then trading someone the Z6 tranny, P28, linkage, and manifold for them to do the swap, and on top of that he is gonna give me a Fields AFC-VTEC controller along with a wiring harness that was made in japan especially for plugging the controller into the Si ecu
Old Oct 27, 2003 | 01:03 PM
1CiViC1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tw1n Turb0 Z &raquo;</TD></TR><TR><TD CLASS="quote">Cheap is 25 bucks</TD></TR></TABLE>
damn, thats real cheap...
Old Oct 27, 2003 | 01:53 PM
MrTodd's Avatar
Default Re: D16Z6 with D16y8 manifold? (1CiViC1)
It's worth it if you're paying no more than $100 for the Y8 I/M. I too noticed a little more throttle response and mid-high end power with it. Not a very big difference, but a difference nonetheless.
Keep in mind that there are other reasons why the Y8 motor has only 2 more peak HP than the Z6. It's mostly due to the intake port design. Remember that peak HP isn't everything though...
Old Oct 27, 2003 | 02:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1CiViC1 &raquo;</TD></TR><TR><TD CLASS="quote">
damn, thats real cheap...</TD></TR></TABLE>
not really
the one s i got on my car wich is the one on the picture i got it for free
Old Oct 27, 2003 | 02:47 PM
MrTodd's Avatar
Default Re: D16Z6 with D16y8 manifold? (USDM 4G VTEC)
Dude, I paid $100 for mine! Looks like I got screwed... But at least it did come with everything (fuel rail, all sensors, t/b, injectors, etc).
Old Oct 27, 2003 | 04:19 PM
1CiViC1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
not really
the one s i got on my car wich is the one on the picture i got it for free</TD></TR></TABLE>
naw, 25 is cheap. you on the other hand fuckn scored
Old Oct 27, 2003 | 11:37 PM
Well from what I'm seeing I'll need to do the OBD I conversion to go with the Y8 mani.
IntegraXSi mentioned running an OBD 0 y8 setup.....How is this achieved effectively?
Old Oct 28, 2003 | 04:48 AM
Default Re: (Tw1n Turb0 Z)
from here - https://honda-tech.com/zerothread?id=573612
sorry for the shitty pic...my wonderful scanner turns everything into garbage.
this is a 96-98 d16y8 intake manifold with a 90-91 b18a1 throttlebody, a 99-00 civic si intake in a 88-91 civic/crx. IAT wires have to be extended around a foot or so...IACV wires might have to be extended a few inches also, check to make sure first. TPS plugs right in...stock MAP is used. can use stock obd0 IAT, but have to mount somewhere in intake...or rubber boot for aftermarket intake if you dont like cutting nonreplaceable things. or obd2 IAT can be used with correct plug and will fit in intake as shown. i used a reducer in the line to the dashpot on the TB...cause one plug is big and one is small.
note: i had to use the stock d16a6 throttle cable "crank doohicky thing" instead of the b18a1 disk...because it set the throttle cable at a wierd angle. i also used a 86-87 d15a3 (civic/crx si) throttle cable bracket...cause the upside down d16y8 one didnt fit right for me. also...my y8 manifold didnt come with a IACV so i used one from a 98 f22** accord. if you dont run coolant to it one from a 89 mpfi accord will work if flipped backwards. all injector gaskets are from d16a6, fuel rail is d16y8 and fuel line is d16y8 (but stock will work if aligned right).
the fast idle thermo valve is unplugged from the harness and not used at all on the y8 manifold...it will not throw a CEL.
make sure to check TPS voltage...it will hold idle, i promise.
Old Oct 28, 2003 | 09:58 AM
xci_ed6's Avatar
Default Re: (fastcrxsi90)
One reason the Y8 makes less top end power is the assymetricle intake ports. The manifold/header were probably added to make up the ports.
-Dustin
Old Nov 23, 2003 | 12:51 PM
AgentJam's Avatar
Default Re: (krustindumm)
If you are Putting a Y8 manifold on a Z6 engine does everything from the Z6 line up? injectors/rail/sensors/etc.??? I'm considering this swap on my existing D16Z6.
~Vince
spillihpmada
Dec 19, 2007 03:23 PM
suspendedHatch
Aug 23, 2006 08:56 AM
5.0 Killa
20
Jul 2, 2004 01:00 PM
blackccoupe
Aug 21, 2003 02:24 PM
Iceycrx
Sep 28, 2002 05:19 AM
