which one ys1 92 gsr or y1 jdm b16 w/ lsd?
Old Oct 26, 2003 | 09:02 PM
curt801's Avatar
Default which one ys1 92 gsr or y1 jdm b16 w/ lsd?
I have both of these trannies. the ys1 grinds third. which one should i use? i am swaping a b17 into 88 crx. everyone seems to like the ys1 for the gearing. are the y1 better since the have lsd?
Old Oct 26, 2003 | 09:20 PM
mmuller's Avatar
Mad Scientist
Default Re: which one ys1 92 gsr or y1 jdm b16 w/ lsd? (b1788crx)
the ys1 has a shorter final drive (4.4)
the y1 has a 4.26 final drive but has lsd
also the 92-up teggie came with the bigger spline
Old Oct 27, 2003 | 05:59 AM
curt801's Avatar
so which one should i use? i am probably going to use the y1 since it has lsd and because the ys1 grinds 3rd
Old Oct 28, 2003 | 06:09 AM
curt801's Avatar
ttt
Old Oct 28, 2003 | 07:36 AM
whiteyg2rs's Avatar
Don't forget these trannies use different clutch discs. '92 and up require a different disc which is what the gsr ys1 is. I'd say go with the y1, or sell it to me.
Old Oct 28, 2003 | 09:03 AM
CHEETAH's Avatar
you can do alot more with the ys1 than you can with the y1.
Greg
Old Oct 28, 2003 | 09:04 AM
curt801's Avatar
do you know how much a stock clutch disc is?
Old Oct 28, 2003 | 09:06 AM
curt801's Avatar
for the y1
Old Oct 28, 2003 | 09:59 AM
Katman's Avatar
I'd go witht he JDM B16A YS1 w/LSD tranny if you have access to one. If it has grinding problems you can use the syncros out of a hydro 92-95 B16A Y21 transmission, US or JDM, since the YS1 & Y21 use the same internals (bigger spline).
Old Oct 28, 2003 | 10:18 AM
curt801's Avatar
the jdm b16 is the y1(lsd) not the ys1 (no lsd)92 gsr which has the grind in third
Old Oct 28, 2003 | 10:28 AM
ricodemus's Avatar
Default Re: (b1788crx)
This is a tough question. The YS-1 would be better if it didn't have a grind. I'd say use the y1 for now. I have a y1 and it only really sucks in 1st gear, the others are fun to go through. As you save up money, maybe you can get the ys1 fixed and throw in a quaife? That would be a badass tranny. I think you will be more pissed with a grind rather than a tranny you think is slowing you down a little. By the way, LSD is great.
Old Oct 28, 2003 | 10:35 AM
curt801's Avatar
thanks for the info rico
do you know how much a stock clutch plate for the y1 cost? i am looking foward to the lsd of the y1.
Old Oct 28, 2003 | 04:14 PM
curt801's Avatar
ttt
Old Oct 28, 2003 | 07:30 PM
Jeff C's Avatar
Fix the grind in the YS1 and install a Quaiffe.
Old Oct 29, 2003 | 02:57 PM
Deetz's Avatar
Crazy Honda Guy
One thing nobody asked was, do you know for sure your Y1 has lsd, because not all of them do. Your first post implies they all have it, but not true. Just make sure by checking the casing for the "lsd" stamp or check the hole through the tranny where the axels go, you should be able to see right threw. If no lsd on the Y1, then definitly fix and go with the YS1.
Old Oct 29, 2003 | 09:04 PM
curt801's Avatar
so how do i check?
i think i already know. i can see all the way through it.
Old Oct 30, 2003 | 06:48 AM
curt801's Avatar
bump
Old Oct 30, 2003 | 08:22 AM
Deetz's Avatar
Crazy Honda Guy
Sounds like your a lucky man............
Old Oct 30, 2003 | 08:37 AM
curt801's Avatar
i thought i had it. i am looking foward to the lsd. probably going to be selling the ys1 in a couple of weeks.
Old Oct 30, 2003 | 09:05 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b1788crx &raquo;</TD></TR><TR><TD CLASS="quote">i thought i had it. i am looking foward to the lsd. probably going to be selling the ys1 in a couple of weeks.</TD></TR></TABLE>
some cable LSD tranny's also have an LSD stamp as seen here:
Old Oct 30, 2003 | 11:09 AM
curt801's Avatar
thanks for the help.
Old Nov 3, 2003 | 10:34 AM
curt801's Avatar
if i use the y1 i need a new clutch plate and is that it? can i use the 92 integra gsr axcles with the y1?
Old Nov 3, 2003 | 10:47 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b1788crx &raquo;</TD></TR><TR><TD CLASS="quote">if i use the y1 i need a new clutch plate and is that it? can i use the 92 integra gsr axcles with the y1?</TD></TR></TABLE>
yes, you can use any 90-93 integra axles with the Y1 tranny, they're all the same, just make sure you have a B16 half-shaft, as some of the US 90-93 integra half-shafts can differ in length sometimes (auto tranny has a longer half-shaft if im not mistaken).
As far as the clutch goes for Y1 tranny, I believe you should look into using a 90-91 integra clutch as the 92-93 YS1 tranny's might be different in spec due to the bigger spline.
Old Nov 3, 2003 | 11:39 AM
curt801's Avatar
thanks for the info. do you know anywhere i can get a stock clutch for cheap?
Old Nov 3, 2003 | 12:36 PM
Katman's Avatar
uhh not in UT. you might just wanna call around your town and see what you can find.
