not enough sparks?
Old Oct 26, 2003 | 08:56 PM
geezer06's Avatar
Default not enough sparks?
just like the topic says, i think i'm not getting enough sparks. we tested for spark but there was only a lite spark, not heavy. is it suppose to be heavy or lite? it also seems like the combustion chamber is getting flooded with fuel cuz everytime i check the spark plugs after trying to crank, (which doesn't start), there seems to be wet fuel on the plugs. i hope this makes sense. this is on a 95 gsr in a civic coupe. note: compression is at (4)140 (3)140 (2)140 (1)120 and car won't start
Old Oct 26, 2003 | 09:12 PM
mmuller's Avatar
Mad Scientist
Default Re: not enough sparks? (geezer06)
check the coil, also those comp.#'s are low. Check cam timming, put a cap of oil in the cylinders to see if comp goes up
Old Oct 26, 2003 | 09:14 PM
geezer06's Avatar
Default Re: not enough sparks? (mmuller)
i'll give it a shot...thanks for the help
arcticbluealex
Jul 8, 2014 08:06 PM
btbomb
Mar 30, 2008 08:30 PM
Honda Hick
Feb 28, 2005 09:20 AM
SwiftTypeR
Oct 20, 2004 07:49 PM
g2turbo
Sep 17, 2003 08:31 PM
