Civic instrument cluster
Old Oct 26, 2003 | 07:50 PM
wdskuk's Avatar
Default Civic instrument cluster
I'm going to replace my instument cluster with a si one. Do I need to take my steering wheel off to take out my cluster. Also will all the plugs fit together like stock without cutting anything.
Old Oct 26, 2003 | 07:53 PM
b16egsi's Avatar
Default Re: Civic instrument cluster (wdskuk)
You dont need to take off the steering wheel. The install is pretty easy, just have to get into small places. As far as the wires, they should fit, the only concern will be the tack and the speedometer, there the same so they will read differently while driving. ex. if you are really doing 50 the si cluster my indicate you are doing 65.
Old Oct 26, 2003 | 07:56 PM
Ricey McRicerton's Avatar
Default Re: Civic instrument cluster (bcmatzen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bcmatzen &raquo;</TD></TR><TR><TD CLASS="quote">As far as the wires, they should fit, the only concern will be the tack and the speedometer, there the same so they will read differently while driving. ex. if you are really doing 50 the si cluster my indicate you are doing 65.</TD></TR></TABLE>
You need to take out 2 screws in the top of the surround. There are some clips on the bottom, and you can just pull the surround out. Once that is gone, there are 4 screws holding the acutal guage cluster in. Pop those out and then unplug it. It will plug and play into the SI cluster, and disreguard what he said ^^^. He apparently does not know what he is talking about.
JAYB90
15
Feb 12, 2009 03:29 AM
jdmsohc2nr
Feb 4, 2009 08:16 PM
turbodelsolb16a2
12
Oct 22, 2008 10:52 AM
beginnerbreaker
Honda Civic (2001 - 2005)
Feb 22, 2008 12:59 PM
audio5050
Feb 14, 2007 07:22 PM
