B18C and B16A2 fuel and timing
Old Oct 26, 2003 | 07:31 PM
Formula 1's Avatar
Default B18C and B16A2 fuel and timing
ok i have a 00 si but i have a 94 jdm gsr long block with si tranny and si ecu ...also a VAFC hooked up...right now im running 20% correction on fuel. I am still throwing a code 23 - Knock Sensor, i replaced the knock sensor and i have a brand new wiring harness so im good there. My question is why would this still be doing this it was running lean before but now with the correction it sounds ok. Im wondering also if the b16a came with more aggressive timing than the gsr did. anything would help fuel maps timing maps or just general knowledge
Old Oct 26, 2003 | 11:11 PM
Formula 1's Avatar
Default Re: B18C and B16A2 fuel and timing (SikCivic)
anything?
Old Oct 27, 2003 | 07:41 AM
Formula 1's Avatar
bump for some info
Old Oct 27, 2003 | 10:32 PM
That Dood's Avatar
I think the b16 has even more aggressive timing than a type r. Thats how they are pretty rowdy for a little motor. Even adding cams to them to fell a big difference which I think is the timing issue. Fuel on the other hand I think is a good amount less.
codenamezero
Sep 11, 2011 09:55 AM
an2ny888
Mar 11, 2005 10:38 PM
sleeperb16a
Nov 19, 2004 07:32 AM
tc
Sep 22, 2003 06:10 AM
Ex-ITR5874
Jun 20, 2002 03:15 PM
