is high oil pressure bad for an engine?
Old Oct 26, 2003 | 04:53 PM
91integraLSVTEC's Avatar
Default is high oil pressure bad for an engine?
i just put a type r ac delco oil filter (didnt have puraltor the blue kind) in my lsvtec, seems that i'm getting 84 psi of oil pressure at 3k rpms.. is that bad?? i have a shimmed ls oil pump that peaks out 92 psi but i usually get 78 psi at 3k rpms.. please let me know if it hurting my engine i'll change that bitch right away..
Modified by 91integraLSVTEC at 9:29 PM 10/26/2003
Old Oct 26, 2003 | 05:11 PM
non-VTEC's Avatar
Default Re: is high oil pressure bad for an engine? (91integraLSVTEC)
84psi it high but not enough to really worry about.............92psi is pretty high.......i dont think you want much more than 95-100psi before you start blowing out seals........
how thick is your oil?
Old Oct 26, 2003 | 05:33 PM
Default Re: is high oil pressure bad for an engine? (non-VTEC)
i'm using regular castrol gtx 10w-30the high oil pressure is killing the motors performance i'll have to change that oil pump for a gsr oil pump soon.. i'm just glad that high oil pressure isnt harming my engine
Old Oct 27, 2003 | 02:37 PM
non-VTEC's Avatar
stick with 5W30 in that case........
and try to stick with the OEM honda filters or something similar.........
DumpdEJ6
Sep 23, 2019 04:48 AM
DumpdEJ6
Dec 11, 2016 06:26 AM
fr3dy_1
17
May 23, 2008 11:33 PM
H22T94
Jul 10, 2004 11:27 AM
gaskleppie
Sep 27, 2003 06:45 AM
