in dash tach in 97 hatch
Old Oct 26, 2003 | 03:49 PM
ENJOI's Avatar
Default in dash tach in 97 hatch
my friends got a 97 hatch with no tach. he wants a tach. which cluster would i use?? i heard that the sedan has a tach..
Old Oct 26, 2003 | 03:51 PM
xXx Justin xXx's Avatar
Default Re: in dash tach in 97 hatch (ENJOI)
i think the 96-00 ex cluster will just plug straight in......they have tach with 7k redline.!
since your new here, before somebody says it like an *******....for simple things like this..or things that seem like they would be common for poeple to do. just click the search in the upper right corner...this is covered plenty of times...you'll get a lot further here...people are quick to scream SEARCH n00b!!!!!...make you feel un-wanted..just keep that in mind. always try it first, then post if you dont find it!!!!!!!!!!
Old Oct 26, 2003 | 03:54 PM
WeaKSouL's Avatar
Default Re: in dash tach in 97 hatch (SOHC Beast)
correct! or just get a tech from the civic SI
Old Oct 26, 2003 | 04:06 PM
ENJOI's Avatar
Default Re: in dash tach in 97 hatch (WeaKSouL)
thanks for the help. i am fairly new to this site, but have been on the vwvortex for about a year and know all about the seach function and about bashing noobs. but i didnt know what to search for. thanks
Old Oct 26, 2003 | 04:13 PM
EricUSC's Avatar
If you have the stock D-Series engine, then go for the 96-00 Civic LX cluster. The LX has the same engine SOHC non-VTEC that came stock in your car, so the redline would be correct.
Old Oct 26, 2003 | 04:31 PM
Ricey McRicerton's Avatar
Default Re: in dash tach in 97 hatch (EricUSC)
I vote for the EX cluster. I've got one in my car and just did all of my lighting amber!! Looks great!
EDIT: The LX came with a tach??
Old Oct 26, 2003 | 04:49 PM
ENJOI's Avatar
Default Re: in dash tach in 97 hatch (Ricey McRicerton)
so i should be looking for a lx cluster??
Old Oct 26, 2003 | 05:02 PM
Yeah, check for the LX cluster, but the EX cluster will work just as well, only with a little higher redline (whoevers car it is going on is going to have to watch the numbers on the tach instead of the colors, but that's not hard at all)
sam hain
Nov 1, 2013 09:29 AM
lowkey
Jun 30, 2004 09:33 AM
Hatchdude
Jan 13, 2004 07:42 PM
6ghatch
Feb 2, 2002 08:10 AM
