USDM B18C1 buildup-mild(tell me what you think)
Old Oct 26, 2003 | 01:15 PM
BLK JDM's Avatar
Default USDM B18C1 buildup-mild(tell me what you think)
Just putting letters to pad to my very mild, very daily driven 92 CX hatchcrap.
I just purchased a 97 USDM B18C1 motor because a rod exploded through my bone stock 98 USDM B20B4.
Anyway plans include and some parts are already purchased:
AEM short-ram(sorry I will not run a cold air)
ITR Throttle Body
Skunk2 Intake Manifold
OE Intake Manifold Gasket/or Hondata(does it really matter????)
EF-1 M22 cams/valvetrain
Some mild port and polish work
AEM cam gears
Unorthodox Type R crank Pulley
MSD SCI Ignition w/ external coil
JDM DC Sports 4-1 header w/ 2.5" collector(I may buy a used AN-R from a friend)
2.5" inlet/outlet Carsound Cat
Apexi N1 full catback exhaust
This is all mated to a JDM ITR tranny w/ Clutchmasters Stage 4 clutch and lightened flywheel.
So what kind of whp would I be looking at??
Now finally(I know it's a lot of reading) to my actual question. I want to add ITR pistons but is it really worth it. Most people say with the cams I really just need to bore it out. I DO NOT have the money for higher comp. pistons or to bore out the bottom end to 84.5mm. Is the ITR pistons worth it?? I think CTR pistons are a little too high for daily driveability. Am I wrong?? What about shaving the head?? What about a thin headgasket.
My problem is money I do not have money to bore out the block so I'm basically trying to find a quick fix for my cams.
Old Oct 26, 2003 | 01:19 PM
igotyofire's Avatar
Default Re: USDM B18C1 buildup-mild(tell me what you think) (jigga008_99)
cams like compression not displacement, and i dont know about those cams but u should be fine people proably meant ull need higher compression becuase with a gsr it is a lil low, some itr pistons wouldn't be a bad upgrade at all, if you dont want to go with ctr pistons then i would get jdm p30 piston or JDM-R pistons
Old Oct 26, 2003 | 01:20 PM
philafelman's Avatar
oem pistons are not that much(p73's, pr3's, pct's, p30's)...its only about $250 with new rings, and you can just get standard bore so you dont gotta worry about machine work.
Old Oct 27, 2003 | 04:42 AM
SashK's Avatar
Default Re: USDM B18C1 buildup-mild(tell me what you think) (philafelman)
i'd go with some ctr pistons
Old Oct 27, 2003 | 06:03 AM
BolivianDc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jigga008_99 &raquo;</TD></TR><TR><TD CLASS="quote">
My problem is money I do not have money to bore out the block so I'm basically trying to find a quick fix for my cams.</TD></TR></TABLE>
If you bore it out, your going to have to sleeve, so do it right the first time and get pistons/rods if you bore. If you keep stock bore, I would say drop in USDM R pistons, or b16 pistons to get around 11.5.
I would also ditch the ITR TB, MSD Ignition, Crank pulley and apexi 60mm exhaust
Replace them with bored out GSR tb, get new plugs, take off PS/AC (if you didnt already), and get a 2.5 inch exhaust to complete the system.
Get the gasket from AN-R.com, same as hondata but 1/2 the price
If you are putting all that work into a hatch w/ a JDM ITR tranny it would be really quick
Old Oct 27, 2003 | 01:21 PM
BLK JDM's Avatar
Default Re: USDM B18C1 buildup-mild(tell me what you think) (Bolivianstrtwpn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bolivianstrtwpn &raquo;</TD></TR><TR><TD CLASS="quote">
If you are putting all that work into a hatch w/ a JDM ITR tranny it would be really quick</TD></TR></TABLE>
Why a bored out GSR throttle body?? What's wrong with the MSD Ignition?? I already have JDM NGK 8mm wires and plugs. Isn't the Apexi N1 already 2.5"(I really think mine is). I have a CX hatch, I already don't have PS/AC. The Crank pulley doesn't have anything but the alternator spot for the belt(that's why I have it b/c it deleted the spots for PS/AC.
Oh yeah I know if I bore it out I'll need new pistons/rods. Well I think my decision may be made for the USDM ITRs-I'll check how much they cost compared to the B16s.
Thanks man
Old Oct 27, 2003 | 01:26 PM
Thanks man</TD></TR></TABLE>
b16's and itr's should be the same price.
Old Oct 27, 2003 | 01:28 PM
BLK JDM's Avatar
Ok good that's makes it even easier. Thanks- don't the B16s have just a little more compression??
Old Oct 27, 2003 | 01:37 PM
junya16's Avatar
just get some .25 oversized itr or ctr pistons to give your car a fresh bore and hone...msd ignition isn't bad but its not necesarry w/ your setup...and if its a daily driver i'd keep the ps/ac....its worth keepin...
Old Oct 27, 2003 | 01:50 PM
BLK JDM's Avatar
Default Re: USDM B18C1 buildup-mild(tell me what you think) (junya16)
I have a 92 CX it didn't come with either PS or AC. So I've never had the joy of having either. I was thinking of adding A/C but I have no clue how hard that would be but it just seems like crazy work. I'll probably never do it or get a lot of friends to help me do it.
Old Oct 28, 2003 | 09:42 AM
Get the stock GSR TB bored out because it's only around $100 compared to $200+ for an ITR TB. Your getting plenty of spark with new spark plugs, the ignition would be a waste of money at this point. Apex exhausts are 60mm for hondas, with almost no exceptions
Old Oct 28, 2003 | 10:28 AM
BLK JDM's Avatar
I already have the MSD ignition and the Apexi N1 exhaust. Where can I find a bored out GSR throttle body or where can I get someone to bore out the one I have.
Old Oct 28, 2003 | 10:39 AM
TB bore https://honda-tech.com/zero...age=2
Old Oct 28, 2003 | 11:29 AM
BLK JDM's Avatar
Thanks man you've been a lot of help.
Old Oct 28, 2003 | 11:33 AM
[tk4L] Doke's Avatar
https://honda-tech.com/zerothread?id=598452 sounds kind of similar to mine..but yea...the skunk 2 intake mani is really going to help..
Old Oct 28, 2003 | 03:13 PM
BLK JDM's Avatar
Default Re: USDM B18C1 buildup-mild(tell me what you think) (NAsty coupey)
Nice setup man. Hopefully mine will do like yours or even better because I'm going to up the compression and I have cam gears.
BLK JDM
Aug 18, 2005 11:11 PM
Hybrid96EK
38
Dec 29, 2004 02:40 PM
sd_pinoy858
16
Feb 22, 2004 04:41 PM
neo1z
Mar 6, 2002 02:57 PM
n1racer
Aug 3, 2001 05:05 AM
