ahhhh....help me decide
i cant decide to either go turbo or all-motor in my g2....i was thinking that if all motor im goin to go the poorman ITR set-up and look to gettin 200 whp.
but, then theres the temptation to go th"darkside"....i just cant decide, i was hopin yal can help me out
go to the darkside. you wont regret it. trust me with turbo you cant achieve 200+ whp without even trying while with NA you can get it but it will cost you $$$$$$$$$$.
see it goes like this i have a b18a that needs a rebuild.....but i cant decide which direction to go i know that turbo will get me more power, is it really that hard to pull 200 whp out of a poormans type-r set-up(meaning it costs alot)
Turbo your poor man's ITR.
I'm building a poor man's ITR right now so you know which way I would swing you. I am fortifying my block enough though since I'm going to be moderately spraying. If I ever decided to go low boost though, I'll be able to do so. I like being NA though.
i think i might have figured out my set-up....im thinking since b16's like turbos , i might get a b16 put forged rods,and pistons and put a drag gen 3 turbo kit on it
me and my cousin both run g2 tegs. and definately saying a go on turbo.. I'm personally all n/a but my cousin teg run around 210, with cams upgrade, turbo, and port and polish job.. But for all n/a i say run high compression pistons on b20, upgrade valves, port and polish job, and air fuel controller .. should help u punch around 190 to almost 200 depend on setup.. but that just my views i dont know what any one else thinks about that tho
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllmotorJunkie »</TD></TR><TR><TD CLASS="quote">If you got the money...go allmotor.</TD></TR></TABLE>
more satisfaction!!!!
less HP
less HP
personally i would go wit all motor if you got the money...i got a real ITR in my g2 and lovin it...its hard as **** to get it goin but once shes goes she goes...if u want to know what i got hit me up on aim UEGOALIE1
k...i decided to go turbo...im gonna build the engine and i was wondering how much would it cost to sleeve b16 and who is a good one to use...also how much does it cost to blueprint and balance a block?
what is a good management sysetem to use when pushin like 10-15 p.s.i?
InfamousRS
Jan 16, 2002 06:17 PM
