preping the engine bay?
Old Oct 26, 2003 | 11:20 AM
BLUE EH3's Avatar
Help we my pennies
Default preping the engine bay?
how should i prep the bay, sould i bolt in all my mounts to the car first or?
Old Oct 26, 2003 | 04:20 PM
Gsr_Hybrid_theory's Avatar
Default Re: preping the engine bay? (BLUE EH3)
take the harness off the motor completly... remove anything not pertaining to the motor swap.... first mount u wanna bolt onto the MOTOR is the rear bracket to the block !!!!!! then align it into th mount... then do the timin belt mount then the trans mount then the 2 mounts on the side...
MAKE SURE THE REAR BRACKET IS ON THE MOTOR FIRST... LOWER IT ON TO THE MOUNT... ur life will be so much easier that way
Old Oct 26, 2003 | 06:21 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: preping the engine bay? (Gsr_Hybrid_theory)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gsr_Hybrid_theory &raquo;</TD></TR><TR><TD CLASS="quote">take the harness off the motor completly... remove anything not pertaining to the motor swap.... first mount u wanna bolt onto the MOTOR is the rear bracket to the block !!!!!! then align it into th mount... then do the timin belt mount then the trans mount then the 2 mounts on the side...
MAKE SURE THE REAR BRACKET IS ON THE MOTOR FIRST... LOWER IT ON TO THE MOUNT... ur life will be so much easier that way </TD></TR></TABLE> harness?
i guess i said it wrong, what should be done b4 u drop the motor in?
Old Oct 27, 2003 | 08:00 AM
martini's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote"> harness?
i guess i said it wrong, what should be done b4 u drop the motor in?</TD></TR></TABLE>
he meant wiring harness.
You dropping the tranny in at the same time as the motor, I assume? Well then, I would change the tranny fluid while the thing is out.
I personally, would install anything you can onto the engine while it's out. Intake manifold included.
Old Oct 27, 2003 | 09:14 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: preping the engine bay? (martini)
ur correct
Old Oct 27, 2003 | 09:19 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by martini &raquo;</TD></TR><TR><TD CLASS="quote">
I personally, would install anything you can onto the engine while it's out. Intake manifold included.</TD></TR></TABLE>
install the engine harness on the motor before u drop in the motor...just be careful not to crush any plugs when lowering it in.
ConceptVBS
Honda Civic (2001 - 2005)
Apr 17, 2014 06:14 AM
Dkahn18
Oct 23, 2008 05:37 PM
endo617
11
Jun 28, 2008 12:18 AM
efyou
Jul 3, 2007 03:00 PM
boostin4door
May 23, 2005 04:41 AM
