Should I use 3 QUARTS of tranny fluid ???
Old Oct 26, 2003 | 11:06 AM
TypeRuz's Avatar
Default Should I use 3 QUARTS of tranny fluid ???
i'll be changing my tranny fluid soon with Honda MTF, and i think i remember posts a while back about adding extra tranny fluid for better shifting/better protection.
i know it takes 2.2 q, but will adding the extra 0.8 have any benefit?
any drawbacks?
thanks!
Old Oct 26, 2003 | 11:26 AM
Chris93Si's Avatar
Default Re: Should I use 3 QUARTS of tranny fluid ??? (TypeRuz)
You should not overfill the tranny. Once it starts to overflow stop pouring
Old Oct 26, 2003 | 12:31 PM
thrty8street's Avatar
bump.
Old Oct 26, 2003 | 12:47 PM
Jason's Avatar
Default Re: Should I use 3 QUARTS of tranny fluid ??? (Chris93Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris93Si &raquo;</TD></TR><TR><TD CLASS="quote">You should not overfill the tranny. Once it starts to overflow stop pouring </TD></TR></TABLE>
ditto, I think Honda would know and recommend more fluid if it were necessary...
but you should BUY 3 qts
Old Oct 26, 2003 | 02:43 PM
twuelfing's Avatar
they wouldnt recommed more fluid if it hurt thier MPG rating or cost them a ton of money (.7qts x 100,000 cars = a heap of cash)
Old Oct 26, 2003 | 06:33 PM
92TypeR's Avatar
FSAE
Default Re: (twuelfing)
I've always been told (and always practiced) filling until it starts to pour out. This usually puts me a hair over 2 quarts on level ground.
Old Oct 26, 2003 | 07:05 PM
threatcon13's Avatar
New User
Default Re: (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">I've always been told (and always practiced) filling until it starts to pour out. This usually puts me a hair over 2 quarts on level ground.</TD></TR></TABLE> yes, mine required all of 2 quarts...didn't crack open the third bottle.
Old Oct 26, 2003 | 07:21 PM
baonest1's Avatar
Default Re: (Threatcon13)
you should always measure on a level surface, or at least make the car level.
that is not soo easy when the driveway is slanted or whatever. so just open up the VSS gear. and pour ~2.3 quarts in. maybe 2.5 so you know you are good to go. measure it using the side of the containter
Old Oct 27, 2003 | 10:48 PM
One Bad GeeSeeR's Avatar
Default Re: (baonest)
now would it overflow if you fill from the vss? also would it hurt putting 3 qts?
carlo
Old Oct 27, 2003 | 11:00 PM
Gerhard_001's Avatar
putting the MTF back in through the fill plug there is no way you can overfill the tranny as you will have .80 quart of MTF on the ground, you can overfill putting it back in through the VSS. Don't put three quarts of MTF in you will ruin your tranny.
Old Oct 27, 2003 | 11:01 PM
Default Re: Should I use 3 QUARTS of tranny fluid ??? (Gerhard_001)
sorry for asking how does it ruin your tranny by putting in an extra .8 quarts?
Old Oct 28, 2003 | 01:00 PM
TypeRuz's Avatar
Default Re: Should I use 3 QUARTS of tranny fluid ??? (One Bad GeeSeeR)
bump
Old Oct 28, 2003 | 01:23 PM
lanceh's Avatar
25 Year Member
i really don't understand why there is a question. put in the recommended amount.
Old Oct 28, 2003 | 01:24 PM
Chris N's Avatar
Default Re: (lanceh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lanceh &raquo;</TD></TR><TR><TD CLASS="quote">i really don't understand why there is a question. put in the recommended amount.</TD></TR></TABLE>
which is TWO POINT THREE QUARTS.
Old Oct 28, 2003 | 01:29 PM
Nameless RB26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by One Bad GeeSeeR &raquo;</TD></TR><TR><TD CLASS="quote">sorry for asking how does it ruin your tranny by putting in an extra .8 quarts? </TD></TR></TABLE>
It could. But why do you want to do that?
It can cause excessive foam and you might see fluid bubbling out of the vent tube. Not smart.
I *believe* there can possibly be damage by overfilling it. I learned about it once, but I do not want to say anything considering that I don't remember exactly what it was...
Old Oct 28, 2003 | 04:24 PM
92TypeR's Avatar
FSAE
Default Re: Should I use 3 QUARTS of tranny fluid ??? (Nameless EJ6)
95% of the time, when you overfill, it will leak out of your axle seals because of the buildup of pressure.
Old Oct 28, 2003 | 04:58 PM
asmallsol's Avatar
Default Re: Should I use 3 QUARTS of tranny fluid ??? (92TypeR)
This goes for both tranny fluid and your normal oil change, when you over fill it, the built up pressure can blow out seals real quick.
Buy three quarts, use about a half a qt to pour through and kinda flush the tranny, then put the drain plug back on and then fill her up.
phateless
Jun 23, 2009 10:39 AM
purple98ek
Jun 6, 2007 06:18 PM
AlekSir
Mar 22, 2005 07:20 AM
Bigwool
Dec 17, 2004 07:56 PM
EF-9SiR
10
Nov 3, 2002 07:57 AM
