which piston would yeild a higher compression?
Old Oct 26, 2003 | 06:45 AM
SupaFly_Honda's Avatar
Default which piston would yeild a higher compression?
jdm pr3, or jdm ITR? This will be going onto my "poormans ITR motor" using the pr3 head. I want the highest cr possible without the valve clearance issue.
Old Oct 26, 2003 | 07:25 AM
snowseeker's Avatar
Default Re: which piston would yeild a higher compression? (SupaFly_Honda)
CTR will give you the highest.
If you can only choose between the ones you listed it would have to be itr.
Old Oct 26, 2003 | 01:37 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: which piston would yeild a higher compression? (snowseeker)
JDM PR3 are slightly higher then JDM ITR.
tvrsir
Dec 8, 2011 10:17 AM
401tuner
Jul 2, 2007 08:07 AM
TEAM562racing
Oct 15, 2003 01:55 PM
GQ 05YellowEVO8
Apr 14, 2003 05:20 PM
2XS
Nov 20, 2002 12:22 PM
