Pulling ECU harness...where the heck is the other end!?
Old Oct 25, 2003 | 10:39 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Pulling ECU harness...where the heck is the other end!?
I should be gettting my hondata setup sometime this week so I'll be pulling my stock ECU and wiring harness. I was messing around with the car a bit yesterday when I decided to crawl down and see how hard getting the harness off is going to be. Maybe I need a flashlight or something, but it looked to me as if the other end of the harness just vanishes into the side of the car . Did I just not look hard enough or is this going to be a pain?
< thinks yelling and thrown tools is in the near future.
Old Oct 25, 2003 | 10:44 PM
Eva01's Avatar
Default Re: Pulling ECU harness...where the heck is the other end!? (ActiveAero)
Hmmmm. Ok, I'm guessing you didn't look hard enough? Pulling the ECU is pretty easy. Just remove the side panel on the passenger side foot well. Unbolt the nuts holding the ECU in and unplug the three connections from the bottom of the ECU and that's it.
Old Oct 26, 2003 | 07:01 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: Pulling ECU harness...where the heck is the other end!? (Eva01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eva01 &raquo;</TD></TR><TR><TD CLASS="quote">Hmmmm. Ok, I'm guessing you didn't look hard enough? Pulling the ECU is pretty easy. Just remove the side panel on the passenger side foot well. Unbolt the nuts holding the ECU in and unplug the three connections from the bottom of the ECU and that's it. </TD></TR></TABLE>
I'm guessing you didn't read the post hard enough . I said the other end. I know where the ECU is and my kick panel hasn't been on for 50,000mi. I was talking about the other end of the harness. I have to remove the whole thing to swap in my OBDI-OBDII unit.
Old Oct 26, 2003 | 07:04 AM
Dr Pooface's Avatar
I thought you didn't remove the harness. Isn't there an adapter to go from the harness to your OBDI ecu? Otherwise you'd be re-wiring your whole car.
Old Oct 26, 2003 | 07:07 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: Pulling ECU harness...where the heck is the other end!? (Dr Pooface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">I thought you didn't remove the harness. Isn't there an adapter to go from the harness to your OBDI ecu? Otherwise you'd be re-wiring your whole car.</TD></TR></TABLE>\
Crap! I just realized this . Now I'm going to have to actually unwire my VAFC and put the connections back to stock .
Old Oct 26, 2003 | 09:59 AM
Eva01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, that's what I thought you were saying but then I was like....nah. I couldn't figure out why you would want to remove the entire engine harness. Anyway, looks like you've got it figured out.
nycpatron
Mar 1, 2010 02:14 PM
ludekid4323
Aug 25, 2006 07:01 AM
00000xxx
Apr 9, 2005 07:05 PM
