Parts! Parts! Parts! Parts! Parts! Parts! Parts! Parts! Parts! Parts! Parts! Parts! Parts!
Cleaning Shop
Mallory Low Pressure Fuel Regulator $35, Sale Pending
1st Gen Integra Master Cylinder $40
1st Gen Integra Front Brakes $125
1st Gen Integra Rear Brakes $125
(2) 45mm Weber DCOE $450, Sale Pending
(1) New TWM Dual DCOE Intake 84-87 Civic 1.5L 12V $275
Complete P/S system 92-95 Civic $100, Sale Pending
Master Cylinder w/ Booster 92-95 Civic $25
Gas Tank w/ fuel pump 92-95 Civic Coupe $50
Distributor 92-95 Civic D15 $40
Starter 92-95 Civic D15 $40
Radiator 84-87 Civic 16Wx18Hx1.38"TH $75
Custom Al Caster/Camber Plates 84-87 Civic $200
(2) 4WD Short Blocks 85-87 Civic Station Wagon 74mm $200 each
(1) 4WD Short Block 85-87 Civic Station Wagon 75mm $100
(2) Cylinder Heads 85-87 CRX Si 12V $125 each
Auto Meter 0-15 PSI Fuel Pressure Gauge w/ Isolator $70, Sale Pending
Electromotive HPV1 w/ wheel and sensor $300 - SOLD
Camshaft Pick Up for Electromotive 84-87 Civic $75
3 Sets of 1-7/8x8" springs (375, 450, 500 lb) $30/set
Ultra Shield Economy Race Seat w/ Cover $70
(2) Front Koni Yellows Struts 84-87 Civic $100 - SOLD
4-1 Double Stepped Header EP/GT4 84-87 1.5L 12 V $300
Auto Meter EGT Gauge $60, Sale Pending
29mm New Torsion Bars 84-87 $250 - SOLD
1st Integra 5sp, Just Rebuilt w/ Custom Quaife LSD $1300 - SOLD
New Fast Brakes 10.2" Front Brake Kit for 84-87 Civic
Wilwood Calipers, 2 Sets 2 Piece Rotors (8lb), SST Lines,
Cusotm Mounting Brackets, Pads, Wheel Spacers $950
(4) Like New 13x7 4x100mm 3 mm Offset Panasport
UltraLites w/ Hoosier Autocrossers $650
D16A6 Intake $50
D16A6 Crank $75
Driver's Side Air Bag for 92-95 Civic Coupe, Make Offer
92-95 Under dash HVAC System and Controls, Make Offer
Please contact me at smsproducts@adelphia.net
Modified by SMSP at 9:13 AM 11/18/2003
D16A6 Intake $50
D16A6 Crank $75
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">you got any pics of the panasports?</TD></TR></TABLE>
Sure. They come with 225/45-13 Hoosier Autoxrs.
SMSP - Who never got a chance to run these wheels and always used 19lb custom 13x7 steel wheels.
i helped you out and put a link to this on http://www.g1teg.org you might be able to sell some stuff to someone on there.
aww man, i wish i had more cash.. i am definitely intrigued by the webers, the cg tranny, the panasports, and the fastbrakes kit.
edit: check that.. not the fastbrakes, 10.2" rotors are not 13" wheel friendly, and the price tag is a bit beefy on those.
Modified by shadowboy at 6:32 PM 11/7/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realfasthonda »</TD></TR><TR><TD CLASS="quote">i helped you out and put a link to this on http://www.g1teg.org you might be able to sell some stuff to someone on there.</TD></TR></TABLE>
Thanks man.
Thanks man.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadowboy »</TD></TR><TR><TD CLASS="quote">
Modified by shadowboy at 6:32 PM 11/7/2003</TD></TR></TABLE>
Actually, Brian Hasty built this kit to be used with the 13x7 Panasports, but you won't get anything bigger under there
. Oh, the 2 pieces rotors weigh just 8lbs. This kit is brand new never been used. It will cost you about $1100 new from Fast Brakes.
You would need the Wilwood calipers since they take up less space.
This is what's left
1st Gen Integra/2nd Gen CRX Front Brakes $125
1st/2nd/3rd Gen Integra Rear Brakes $125
(1) 4WD Short Blocks 85-87 Civic Station Wagon 74mm $200 each
D16A6 Intake $50
D16A6 Crank $75
Modified by SMSP at 9:13 AM 11/18/2003[/QUOTE]
D16A6 Intake $50
D16A6 Crank $75
undeniabl3niguh
Jan 20, 2006 06:48 PM
