Race Auto trans
Old Oct 25, 2003 | 05:35 PM
ferio 95's Avatar
Default Race Auto trans
Ok this is probly a stupid question with a simple answer but i never knew the answer. What keeps a auto transmisson from lasting after about 200hp?
Old Oct 25, 2003 | 05:37 PM
P1mpSlap's Avatar
Aftermarket Torque Converter
Old Oct 25, 2003 | 05:38 PM
ferio 95's Avatar
Default Re: (P1mpSlap)
yeah but what would you do to make it hold up in high hp such as turbo
Old Oct 25, 2003 | 06:11 PM
tilt's Avatar
Default Re: Race Auto trans (ferio 95)
Im not sure if this applies to hondas, but i know some auto maxima owners that have their valve body modified so the shifting is much quicker. This helps the tranny last longer and not slip as much when you pushfor more hp.
thanks to whoever this pic is from
You can also cryogen treat the tranny. this supposedly makes the internals stronger
Old Oct 25, 2003 | 08:15 PM
mr.beeks's Avatar
Default Re: Race Auto trans (tilt)
http://www.levelten.com
Modified by big reds at 9:33 PM 10/25/2003
Old Oct 25, 2003 | 08:16 PM
ferio 95's Avatar
seems as this is harder do correctly then a ls/vtec
Old Oct 25, 2003 | 08:23 PM
TEXN3's Avatar
the torque converter and upgraded clutches are what makes the differences. the quickest cars down the 1/4 mile use an automatic...GM turbohydramatic. and good fluids.
Old Oct 25, 2003 | 08:26 PM
ferio 95's Avatar
Default Re: Race Auto trans (texnteg)
..dude that website is about self confidence lol. Anyway... is anyone running at least 12's with a auto? without ridiculous problems?
Old Oct 25, 2003 | 08:28 PM
ferio 95's Avatar
i mean apparently our domestic hot rods dont seem to have any problems with auto tannys so what do they have we dont?
Old Oct 25, 2003 | 08:33 PM
[ iLL ] iNt3GrA's Avatar
they have rear wheel drive
Old Oct 25, 2003 | 08:34 PM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 &raquo;</TD></TR><TR><TD CLASS="quote">..dude that website is about self confidence lol. Anyway... is anyone running at least 12's with a auto? without ridiculous problems?</TD></TR></TABLE>
what are you talking about its wrong!
Old Oct 25, 2003 | 08:39 PM
ferio 95's Avatar
Default Re: Race Auto trans (big reds)
you put in level10 not levelten 2 totally diff websites
Old Oct 25, 2003 | 08:42 PM
ferio 95's Avatar
they want 3500 for a "bullet proof tanny" hah
Old Oct 25, 2003 | 08:51 PM
mr.beeks's Avatar
how much do you think a powerglide tranny is?
Old Oct 25, 2003 | 09:35 PM
ferio 95's Avatar
i no that those trannys are worth the money but do u need all tat just to hold about 10-15lbs of boost?
Old Oct 25, 2003 | 09:46 PM
Ef Whore's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 &raquo;</TD></TR><TR><TD CLASS="quote">Ok this is probly a stupid question with a simple answer but i never knew the answer. What keeps a auto transmisson from lasting after about 200hp? </TD></TR></TABLE>
A manual
Old Oct 25, 2003 | 10:05 PM
ferio 95's Avatar
Default Re: Race Auto trans (Ef *****)
yeah that about sums it up lol
Old Oct 25, 2003 | 10:25 PM
Ef Whore's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 &raquo;</TD></TR><TR><TD CLASS="quote">yeah that about sums it up lol</TD></TR></TABLE>
For real, a basically stock Honda Manual trans can handle alot of power with an upgraded differential, and driver that can read the tranny.
Old Oct 25, 2003 | 10:28 PM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 &raquo;</TD></TR><TR><TD CLASS="quote">i no that those trannys are worth the money but do u need all tat just to hold about 10-15lbs of boost?</TD></TR></TABLE>
buy an upgraded torque converter it will almost all you need to run moderate boost. Unless you are planing on running 10s or lower you will not need to bulletproof the tranny synchros itself.
Old Oct 25, 2003 | 10:41 PM
Bspec18's Avatar
I have a turbo Auto with 10psi of boost for over 2 years now and nothing is wrong. I advise you get a large tranny cooler and drive responsible and don't abuse the tranny to much i.e. Manual shifting, or Flooring it often. Right now i'm doing the Auto/Manual conversion just because it cost way to much to build the auto tranny and Manual driving always gives the driver better control. btw the tranny held up fine holding 10psi of boost thru every gear
Old Oct 25, 2003 | 10:47 PM
P1mpSlap's Avatar
Default Re: (Bspec18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bspec18 &raquo;</TD></TR><TR><TD CLASS="quote">I have a turbo Auto with 10psi of boost for over 2 years now and nothing is wrong. I advise you get a large tranny cooler and drive responsible and don't abuse the tranny to much i.e. Manual shifting, or Flooring it often. Right now i'm doing the Auto/Manual conversion just because it cost way to much to build the auto tranny and Manual driving always gives the driver better control. btw the tranny held up fine holding 10psi of boost thru every gear</TD></TR></TABLE>
but if you cant be hard on it what's the point?
It's all in the torque converter people. If that thing cannot spin fast enough to create power you will strip the gears instead.
BTW: you should've got a dyno before and after to see how much HP you are going to free up through the conversion.
Old Oct 25, 2003 | 11:05 PM
Bspec18's Avatar
I agree, I should have dynoed it first. But i have a nice GSR tranny w/LSD and Exedy clutch and flywheel lying next to the car and i was bored. So you kno the story... A simple tranny swap is now also a Motor Build up, a Turbo Upgrade. =P
silentdeath12886
Jun 19, 2006 06:28 AM
gearhead18
Apr 30, 2003 07:14 PM
29psiHybrid
Nov 13, 2002 05:37 AM
paulzy
Sep 2, 2002 12:40 PM
97 teg
Dec 29, 2001 04:38 AM
