1990 integra ls stock intake help
Old Oct 25, 2003 | 03:05 PM
deeice30's Avatar
Default 1990 integra ls stock intake help
their are 3 hoses that attach to the stock intake, 1 coming from the valve cover and the other 2 other ones coming from the top. how do you take out the hoses? my intake only has 2 holes for the hoses. do i put the two hoses from over the top into 1 hole?
Old Oct 25, 2003 | 08:01 PM
aziz93's Avatar
Default Re: 1990 integra ls stock intake help (deeice30)
there should only be one hose coming from the valve cover to the in take tube the other to are i belive coolant going from the head to the block or viseversa so them two get spliced together with a metal tube and the one from the valve cover goes into the intake tube if im not mistaking
Old Oct 25, 2003 | 11:30 PM
BeesDA6's Avatar
Is it an Ebay intake ? You can use a Y or a T fitting for the 2 small vaccum hoses. I ran into that same problem and just did that HTH
Old Oct 26, 2003 | 01:03 AM
DA-MAX's Avatar
yup thats what I had to do...T-fitting worked fine!
Wazup
Jun 28, 2019 09:33 AM
jlowellintegra
Jun 14, 2011 09:59 PM
8083tcman
Nov 29, 2008 09:24 PM
Knight1
Sep 16, 2005 11:44 AM
AMG
Jun 6, 2003 07:55 AM
