all motor route now i need some advice from the all motor crew
Old Oct 25, 2003 | 01:12 PM
92lSilude's Avatar
Default all motor route now i need some advice from the all motor crew
First things first... I/E/H... now the question is... which ones? intake... exhaust... and header...
After that what do you do really... i meen, what order do you do things in, this is my driver so i cantjust sit it aside and build it all at once, its a piece by piece thing... please help... im not going all out drag car... but cams headwork sleeves rods pistons etc... just need to know how to go about it... thanks... BTW...its an H23... which makes it a bit tougher
Old Oct 25, 2003 | 04:21 PM
chris@allmotor.net's Avatar
Default Re: all motor route now i need some advice from the all motor crew (92lSilude)
a 3" intake, a DTR header, and a 2.5-3" exhaust. you should get a h22 head and put that on there too.
Old Oct 25, 2003 | 04:26 PM
12secB18acivic's Avatar
I would port the head first, and than get cams,header and a good ecu.
Old Oct 25, 2003 | 06:42 PM
92lSilude's Avatar
I thought DTR headers were side exit... im lookin for something that is still semi-streetable. and port the head first? really? before i/h/e ?? what i was thinkin was intake header exhaust... then 370cc injectors fuel pump headwork cams camgears and hondata to tune everything. eventually i would sleeve it and run forged pistons.. but thats last.
Old Oct 25, 2003 | 06:43 PM
92lSilude's Avatar
might even run a small 50shot later on for that added boost... but thats after i do everything else
Old Oct 25, 2003 | 06:45 PM
92lSilude's Avatar
btw... not doin H22 headswap... for that amount of money i could run a turbo. Does DTR make a H23 header?
Old Oct 25, 2003 | 06:56 PM
-KangaRod-'s Avatar
Default Re: (92lSilude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92lSilude &raquo;</TD></TR><TR><TD CLASS="quote">btw... not doin H22 headswap... for that amount of money i could run a turbo. Does DTR make a H23 header?</TD></TR></TABLE>
doubt it. Your biggest bang for buck will be the head swap. Then get the IHE.
You're using an inferior product now, why wouldn't you upgrade to the best you can buy before attempting to make the most power from it?
Old Oct 25, 2003 | 07:01 PM
92lSilude's Avatar
because im a broke student and this is going to be an overtime deal and im trying to make the most of what i have considering the H23 isnt that bad but its definately not an h23... anyone know how much the head swap is... ?
Old Oct 25, 2003 | 07:02 PM
92lSilude's Avatar
not an H22***
Old Oct 25, 2003 | 10:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92lSilude &raquo;</TD></TR><TR><TD CLASS="quote">I thought DTR headers were side exit... im lookin for something that is still semi-streetable. .</TD></TR></TABLE>
He make street headers also.
Old Oct 25, 2003 | 11:59 PM
see_our_vtec's Avatar
Default Re: (12secB18acivic)
sadly enough it's not just a headswap. you have to swap out everything that touches the timing belt. the headgasket, the oil squirters and the ecu. the best thing you can do is start out with an h22 and work from there. it's going to be your biggest increase in power. plus h23's don't make for very good allmotor applicants.
Old Oct 26, 2003 | 01:04 AM
TwoRedEGgs's Avatar
Default Re: (JDMlude92)
yeah i think you might be better off starting with a H22, due to the fact that it's all set up and ready for boltons.... you could easily get close to 200 whp with a little work !!
Old Oct 26, 2003 | 05:58 AM
92lSilude's Avatar
anyone know how much an H22 swap is? al included? its from an h23 to an H22 so there might not be as much involved as say dropping an H22 into a civic... i heard the H22 will bolt right up to the H23 transmission right? sounds like a good idea.... the amount of money i would have to spend to get my H23 to the same level as a Stock H22 is probably close to the amount for the swap right lol
h22prelude99
37
Aug 17, 2010 05:57 PM
importfanatic17
Dec 29, 2006 12:08 AM
EP3H
May 1, 2006 05:18 AM
fl_hmong_racer
22
Mar 9, 2005 08:40 AM
eddiecut
Nov 19, 2003 11:03 AM
