Blown headgasket
Old Oct 25, 2003 | 01:03 PM
e30dood's Avatar
Default Blown headgasket
White smoke is coming out of my exhaust and my oil level dropped, I'm probably burning oil I think my headgasket is bad. The white smoke only appears once in a while though and I don't see any blue smoke at least not yet. I'm going to do a compression test. Anywho, I've heard that you can use the z6 gasket for the a6 head and I heard it's better because it's full metal. But I don't know, give me your thoughts. Also my coolant overflows in the overflow tank from time to time.
Also, this is a mini-me swap question but what kind of fabrication needs to be done to the distributor support mounts to make the a6 distributor fit on the z6 head? Thanks.
Old Oct 25, 2003 | 03:17 PM
Malgerus's Avatar
Default Re: Blown headgasket (e30dood)
Get a Y8 head and the distributor should bolt in 100 percent, or so I've heard. Also, you could use a Y8 2 layer head gasket (Z6 is 3 layer). Both are metal. Don't use an A6 gasket... composite HG's suck ***.
Old Oct 25, 2003 | 03:38 PM
e30dood's Avatar
Default Re: Blown headgasket (Mr. S)
Yes I know the a6 distributor bolts on the y8 directly without any fabrication but I have a chance to get a z6 head for cheap. I've heard the z6 gasket is the better of the three. I don't know about the z6 being three layers but I know the y8 head gasket is. Also the y8 head gasket is thinner so I don't really want to raise compression quite just yet.
I'm considering a mini-me swap but I don't know if I should. I'm not sure how much tuning it takes.
Old Oct 25, 2003 | 11:14 PM
e30dood's Avatar
bump...
Old Oct 25, 2003 | 11:17 PM
spaceman's Avatar
you should replace that head gasket asap and while your at it check your thermostat,get a high pressure rad cap if you can
Old Oct 25, 2003 | 11:25 PM
Ef Whore's Avatar
Default Re: Blown headgasket (spaceman)
If you see white smoke than it is coolant, not oil . Your headgasket is shot BTW from what you say. If I were in your shoes and wanted a quick cheap fix, I'd do this. Go buy a OEM y8 headgasket, a 160 degree T-stat, and a helms manual. Throw in the headgasket and the thermostat.(Refer to manual, I'm lazy) This y8 headgasket will slightly bump up your CR. Advance your ignition timing all the way, run 93 octane and have some fun.
Old Oct 25, 2003 | 11:41 PM
e30dood's Avatar
Default Re: Blown headgasket (Ef *****)
Yeah oops, I knew it was coolant but I forgot to post that but I figured my oil level dropped so I was also burning oil too. I just ordered a z6 headgasket. And why would I need a new thermostat? I know my radiator cap seal is bad, I haven't changed that yet, I'll get to it though.
Old Nov 7, 2003 | 01:09 AM
gaydm.accord's Avatar
ok i recently had same problem with ls vtec blown gasket white smoke but its serious now alot of coolant is leaking and ALOT OF white smoke came out on one run after we brough it back it went down to very little smoke but since the gasket is blown if i did compression test would it read wrong thats first q's i need compression test for another reason but here the second coolant and white smoke thats just like water in your system i had hydrolocked f22 motor before now if the gaskets blown the coolant leaks then would these be early symptomns of hydro lock and whats the best way to fix it i know drain and refill drain and refill but that doesnt take care of EVERYTHING and last thing is it driveable with blown headgasket and white smoke comming out of exhaust oh yea and one more important thing the car did die on me 3 times it died on neutral with idle too low then i started it up i let idle get to low again it went out and third time same after that it didnt happen again
mjsotelo91
Jun 16, 2008 01:31 PM
mattie_96
Sep 11, 2006 03:14 PM
mattie_96
Sep 11, 2006 02:26 PM
chippy
Mar 3, 2006 03:56 AM
97grnrs
Dec 10, 2005 11:11 AM
