ITR Pistons
Old Oct 25, 2003 | 07:52 AM
89JDMcrx's Avatar
Default ITR Pistons
I'm installing ITR pistons in b18b. Do you have to modify the head in any way. I use the LS rods right?
Old Oct 25, 2003 | 08:01 AM
91tegrals's Avatar
you can use youre rods but youll have to shave some off each side of the rods..
Old Oct 25, 2003 | 08:05 AM
89JDMcrx's Avatar
Default Re: (91tegrals)
k, my friend keeps on saying that i have to modify the head because the valves will hit.
Old Oct 25, 2003 | 09:11 AM
non-VTEC's Avatar
Default Re: (97exracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97exracer &raquo;</TD></TR><TR><TD CLASS="quote">k, my friend keeps on saying that i have to modify the head because the valves will hit. </TD></TR></TABLE>
valves will not hit........you have to modify the rods to fit those pistons.
why not just get a set of B16 pistons. they fit with no modifications, give you a little more compression and you still wont have to worry about piston to valve clearence........
Old Oct 25, 2003 | 10:20 AM
Newman's Avatar
New User
The valves will not hit the pistons, especially when using VTEC pistons. If you look at any CTR/ITR/SiR/GSR piston, the valve relief is much deeper than that of a LS/B20 piston. That's why you see clearance problems with LS/VTEC or B20-VTEC motors, using the stock pistons, and high profile cams (or Type R cams with the cam timing advanced too much). Then the valves hit the pistons and it's a loud, obnoxious noise. But with the VTEC piston, you won't run into any of those problems as the valve relief is deeper on the VTEC piston, allowing for more clearance for the valves to open up more.
Old Oct 25, 2003 | 12:42 PM
mr.beeks's Avatar
tell your friend to educate himself before giving
the wrong advise..
ITR are just fine just find out a machine shop that has done this
before and while you at it shot peened your rods and change bearings.
Old Oct 26, 2003 | 05:43 AM
89JDMcrx's Avatar
Default Re: (big reds)
alright thanks for the help
b20_driven
Aug 6, 2008 05:20 PM
agp1183
Jan 23, 2006 01:35 PM
ceLtic
Oct 8, 2004 02:25 PM
raifordmotors
11
Sep 15, 2004 01:03 PM
gulftiresinc
Aug 25, 2004 05:34 PM
