2003 si most bang for the buck?
Old Oct 25, 2003 | 07:07 AM
arbo651's Avatar
Default 2003 si most bang for the buck?
my 2003 si has an aem cold air and cat back exhaust.. i was wondering what the best buys as far as engine mods would be.. header? etc..
Old Oct 25, 2003 | 07:47 AM
Peking's Avatar
Default Re: 2003 si most bang for the buck? (arbo651)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arbo651 &raquo;</TD></TR><TR><TD CLASS="quote">my 2003 si has an aem cold air and cat back exhaust.. i was wondering what the best buys as far as engine mods would be.. header? etc..</TD></TR></TABLE>
DC Sports ceramic headers, Hondata (if you can afford it), and suspension upgrades (springs, camber kit, strut bars, Type-S rear sway).
Old Oct 25, 2003 | 10:13 AM
RsxVengeance's Avatar
hondata.
Old Oct 25, 2003 | 01:58 PM
ep3minivan's Avatar
Default Re: (03RSXTypeS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03RSXTypeS &raquo;</TD></TR><TR><TD CLASS="quote">turbo</TD></TR></TABLE>
If you want turbo, I have a kit for sale in my sig.
Hondata is fun too.
Old Oct 26, 2003 | 08:47 PM
Unit-X's Avatar
Default Re: (ep3minivan)
I was told that with hondata, if you go on mountain runs and such and you keep your car at high rpms in V-TEC range and you keep it there, its actually reeaall bad for the car due to the mapping or some crap. Is this true?
Old Oct 26, 2003 | 09:04 PM
Todd00's Avatar
I said I don't want a title!
Default Re: (Unit-X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unit-X &raquo;</TD></TR><TR><TD CLASS="quote">I was told that with hondata, if you go on mountain runs and such and you keep your car at high rpms in V-TEC range and you keep it there, its actually reeaall bad for the car due to the mapping or some crap. Is this true? </TD></TR></TABLE>
I would worry more about sliding off of a cliff on a 'mountain run' than I would about the Hondata harming your motor.
Old Oct 27, 2003 | 04:46 AM
1abSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unit-X &raquo;</TD></TR><TR><TD CLASS="quote">.... in V-TEC range.... </TD></TR></TABLE> well considering it "kick's in" at 2200 rpm.....you are in vtec almost ALL the time
Old Oct 27, 2003 | 06:31 AM
SIRMcD's Avatar
Nitrous is hands down the most bang for yer buck, wot switch, wet system, buy used parts. 200 whp for 600 bucks. Can I get a Hell ya!
Old Oct 27, 2003 | 07:23 AM
Peking's Avatar
Default Re: (SIRMcD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRMcD &raquo;</TD></TR><TR><TD CLASS="quote"> Nitrous is hands down the most bang for yer buck, wot switch, wet system, buy used parts. 200 whp for 600 bucks. Can I get a Hell ya!</TD></TR></TABLE>
Not the way I would go about making power, but whatever floats your boat. Used parts, mybe spending the extra cash would be a better way. When concerning your engine.
Old Oct 27, 2003 | 10:37 AM
SIRMcD's Avatar
nitrous is completely safe when used properly, no diff then any other power adder. It is usually the greedy that pay for new motors, someone hits a stock block with 100 or hp and burned rods are coming yer way, no diff then turning up the boost too much. The most common cause of failure is a part malfunctioning, such as a solenoid, so rebuild them often and no worries, also a hobbes switch is a must, it turns off the nitrous if it detects fuel pressure below a set level.
Old Oct 27, 2003 | 04:37 PM
Peking's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRMcD &raquo;</TD></TR><TR><TD CLASS="quote">nitrous is completely safe when used properly, no diff then any other power adder. It is usually the greedy that pay for new motors, someone hits a stock block with 100 or hp and burned rods are coming yer way, no diff then turning up the boost too much. The most common cause of failure is a part malfunctioning, such as a solenoid, so rebuild them often and no worries, also a hobbes switch is a must, it turns off the nitrous if it detects fuel pressure below a set level.</TD></TR></TABLE>
Yeah, I know. I did alot of research on it before. Good cheap way for power, just don't like having to go and refill the tank. Also to have to endure all the jokes and comments from others. Damn movie, that movie has given us all a bad name (image).
Old Oct 27, 2003 | 07:34 PM
SIRMcD's Avatar
Who says you tell anyone about it!
Old Oct 27, 2003 | 07:35 PM
darkvibe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03RSXTypeS &raquo;</TD></TR><TR><TD CLASS="quote">biut on a 4 banger ur floor board will fall off </TD></TR></TABLE>
Did you ruin your intake manifold too??
Old Oct 27, 2003 | 10:08 PM
Unit-X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03RSXTypeS &raquo;</TD></TR><TR><TD CLASS="quote"> ur floor board will fall off </TD></TR></TABLE>
stop watching the fast and the furious!! j/k
Old Oct 27, 2003 | 10:54 PM
Gerhard_001's Avatar
Other than bolt ons learn how to drive the car to its potential. It is free and the best way to make your car go faster.
Old Oct 28, 2003 | 09:43 AM
SIRMcD's Avatar
Actually that is really good advice!
Old Oct 28, 2003 | 02:09 PM
Type Stephen's Avatar
Take your car to the autocross or drag strip depending on what you're interested in doing to your car. When you've got to the point where you're comfortable doing it, you will find out what you DO need and go from there. Try new stuff out, see what works and truly build up your car they way you want it to behave.
Boosted_Rex.
Honda Civic (2006 - 2015)
Nov 28, 2007 10:04 AM
mrmrry243
Dec 27, 2006 10:50 AM
fireslinge
Jul 11, 2005 07:45 AM
.dave
Jul 10, 2005 06:42 AM
91_EF
13
Jun 22, 2005 01:40 PM
