Replaced Oil Pan Gasket Tonight.
took long b/c he had to remove the fly wheel cover. I'm about to take mine off and weld on oil return line. those damn 3 screws near the tranny are such a bitch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88hf »</TD></TR><TR><TD CLASS="quote">did you only use rtv to seal it? or rtv+rubber gasket? or just the rubber gasket to seal it?
i keep hearing one ways better than another...</TD></TR></TABLE>
Hondabond...there is no substitute.
Congrats BTW....I made a pact with myself long ago that I was done doing OPG and exhaust installs on my back...that work justs sucks!
hey got a ? I replaced my gasket tonight and after I started it started leaking did you use any RTV or anything and I couldnt find torque specs and what order to tighten in so that might be the problem do you know those? Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Slowest »</TD></TR><TR><TD CLASS="quote">took long b/c he had to remove the fly wheel cover. I'm about to take mine off and weld on oil return line. those damn 3 screws near the tranny are such a bitch
you have screws going into your tranny? never seen that before... only bolts hmmm
</TD></TR></TABLE>you have screws going into your tranny? never seen that before... only bolts hmmm
teler86
14
May 18, 2006 05:18 AM
