launching sohc turbo..
whats the best way to launch? my setup greddy sohc kit 98 ex stock gsr rims/tires i notice when im nailing it from the launch i dont even feel any boost..? any tips i dont drag much
two step allow you to full throttle launches without revving it to the max.
usually you set it around 6k (people with slicks), then full throttle and the rev stays at 6k and doesn't go higher. full throttle allows you to build up exhaust gases to pre-spool the turbo.
since you don't have a two-step, launch around 3.0k-3.5k
pulse the throttle, in and out so u build exhaust gas to spool the turbo. when you about to launch jam the gas all the way.
or you can
hold it around 3k, when the tree lights up jam the gas all tha way then pop the clutch.
or you can
