Help Im pissed right now!
Old Oct 24, 2003 | 05:18 PM
slowd16z6's Avatar
Default Help Im pissed right now!
OK, you know the punch pin in the shift rod... My friends always removed it for me. I am taking off the tranny right now by myself and I got the stupid punch stuck in the pin from the top I cant seem to get it out. Is there some secret to getting that stupid pin out and can I do it from the bottom..? Please help!
Old Oct 24, 2003 | 05:20 PM
Miracle_X_Bar's Avatar
Default Re: Help Im pissed right now! (slowd16z6)
yep, get a sledge hammer and keep hiting the punch..it will eventually come out...just be a man about it and suck it up lieutenant!!!
EL Vap133's Avatar
Have you tried using a thick nail and banging it with a hammer?
egturbo's Avatar
haha lol.. sorry to hear man.. took us awhile to take that **** out and the tranny was out side the car.. good luck
Old Oct 24, 2003 | 05:22 PM
slowd16z6's Avatar
I cut my finger... and not much room to really slam at it with anything... Ill get this bitch but if anyone has some other suggestions....
Old Oct 24, 2003 | 05:33 PM
slowd16z6's Avatar
ok I got un stuck from the pin on the top... who the know the best way to attack this pin from the top or bottom? and what size punch should I use?
Old Oct 24, 2003 | 05:40 PM
tonyxcom's Avatar
I use a socket. You know, one of those 1/4" drive long shank 6mm ones that you never use.
Fine a socket that is slightly smaller then the bitch pin. Stick a nail in the socket that you can stick into the center of the pin. that will help keep it centered while you bang the living **** out of it.
Oh, and put an appropriate extension on the socket.
It also helps to lift the car as high as you can to give yourself more room to work.
And please put 2 jackstands, 2 wheel chocks, and leave the jack extended under the front of the car for extra safety, especially if you are by yourself.
Old Oct 24, 2003 | 05:42 PM
slowd16z6's Avatar
thanks that got it out!
Old Oct 24, 2003 | 05:45 PM
tonyxcom's Avatar
damn, I can't even nut that fast.
thundernutz
Sep 27, 2009 04:22 AM
SJR
25
May 19, 2005 04:27 AM
hondaracing1
Jan 1, 2004 12:42 PM
gocivicgo
Aug 15, 2003 01:12 PM
gocivicgo
13
Jun 26, 2003 05:36 AM
