Is any one running Mugen exhaust with test pipe?
Old Oct 24, 2003 | 02:38 PM
Rdriver's Avatar
Default Is any one running Mugen exhaust with test pipe?
I am thinking about ditching the carsound cat for a straight pipe. Is this combo extremely loud? Thanks
Old Oct 24, 2003 | 02:43 PM
Champ R's Avatar
Default Re: Is any one running Mugen exhaust with test pipe? (Rdriver)
Im running the mugen exhaust with T1R testpipe, and its not loud at all. The T1R is resonated tho.
Cheap Bastard's Avatar
New User
it should be hardly noticable in volume, that is as long as you have a resonator.
Old Oct 24, 2003 | 02:47 PM
Rdriver's Avatar
Default Re: Is any one running Mugen exhaust with test pipe? (Champ R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Champ R &raquo;</TD></TR><TR><TD CLASS="quote">Im running the mugen exhaust with T1R testpipe, and its not loud at all. The T1R is resonated tho. </TD></TR></TABLE>
That is good news....How much is the T1R? Does it have an O2 bung or do you just disconnect the O2 sensor?
Thanks
Old Oct 24, 2003 | 02:56 PM
fuck honda-tech's Avatar
i believe its 100 shipped, zerzerotyper was selling one im not sur if it was sold.. they are hard to come by though take a while to get in stock try.
Old Oct 24, 2003 | 03:32 PM
Champ R's Avatar
There is no o2 bung on the T1R design. I have an obd1 ecu, so it eliminates that sensor/check engine light.
Old Oct 24, 2003 | 08:08 PM
Dr Pooface's Avatar
I have the mugen exhaust with the JDM mugen b-pipe (w/ test pipe and resonator). Sounds just a little deeper and louder than stock.
Old Oct 24, 2003 | 08:11 PM
B2FiNiTY's Avatar
Default Re: Is any one running Mugen exhaust with test pipe? (Dr Pooface)
Not that much louder with a test pipe.
Old Oct 24, 2003 | 08:13 PM
jdmspoonitr's Avatar
Default Re: Is any one running Mugen exhaust with test pipe? (B2FiNiTY)
The only difference I noticed with the testpipe is that when it is cold outside there is a swooshing sound when you step on the gas. But I don't notice it anymore.
Old Oct 24, 2003 | 08:24 PM
Cosworth's Avatar
Nah, not loud at all. I ran that setup before. It just stinks w/o a cat.
Old Oct 25, 2003 | 04:56 PM
Rdriver's Avatar
Default Re: Is any one running Mugen exhaust with test pipe? (Cosworth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cosworth &raquo;</TD></TR><TR><TD CLASS="quote">Nah, not loud at all. I ran that setup before. It just stinks w/o a cat.</TD></TR></TABLE>
My car stinks any way....I am actually running part of Sean's old set up.
I guess will try this since I am going Obd1.
Thanks for all the info.
Old Oct 25, 2003 | 04:59 PM
MADEinJAPAN's Avatar
Why don't you just gut your car-sound?
Screw driver and hammer.
Old Oct 25, 2003 | 05:08 PM
Rdriver's Avatar
Default Re: Is any one running Mugen exhaust with test pipe? (MADEinJAPAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MADEinJAPAN &raquo;</TD></TR><TR><TD CLASS="quote">Why don't you just gut your car-sound?
Screw driver and hammer. </TD></TR></TABLE>
The cat was fairly expensive, and nothing is wrong with it. I will keep it around just in case Virginia gets crazy with emissions testing...
Old Oct 26, 2003 | 11:27 AM
yea...The inside of mine broke so it made no difference to me.
But I only paid $175...JHP wants $200 for a J's Pipe. Prollie find one cheaper
Old Nov 5, 2003 | 03:08 PM
WhoisDan's Avatar
I am running a Mugen Cat-back with a 2.5" Test Pipe. The exhaust got a little louder but hardly noticeable. I do in fact have a check engine light cause of the test pipe. Where can I get that thing that turns off the check engine light due to the second 02 sensor?
Old Nov 5, 2003 | 03:11 PM
Big Phat R's Avatar
The mugen exhaust actually gets quite loud if you heat the whole system up a lot (like at the track where you have long periods of WOT)
But most of the time it will be quite mellow.
Testpipes are stinky though.
Old Nov 5, 2003 | 03:18 PM
Chris N's Avatar
Default Re: Is any one running Mugen exhaust with test pipe? (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">The mugen exhaust actually gets quite loud if you heat the whole system up a lot (like at the track where you have long periods of WOT)
Very true. I noticed my fujitsubo was very loud when very hot after a track session. Then, with the test pipe, it got even louder. But for the street, it is not too much louder.
Old Nov 5, 2003 | 08:30 PM
Initial_E's Avatar
nope, not loud at all.
Old Nov 6, 2003 | 10:27 AM
mugenracer's Avatar
Default Re: Is any one running Mugen exhaust with test pipe? (Initial_E)
I just fitted a Phase test pipe to my mugen system (old skool Mugen sport exhaust) i already had a DC JDM 4-1, the test pipe isnt resonated and i get a buzzing noise just below 3k rpm at part throttle and it gets kind of raspy at WOT above 5k....it was only put on yesterday so i'll give it a while, but may need to get a resonated pipe if it doesnt settle down any. Any idea whare i can get a 12" resonated test pipe (this is for a JDM car)????
Old Nov 6, 2003 | 10:38 AM
Brian*'s Avatar
Default Re: Is any one running Mugen exhaust with test pipe? (mugenracer)
A friend has a straight pipe and mugen exhaust on her h/b, and its pretty loud, but not obnoxiously loud
Brian
Kavehman
Mar 15, 2006 01:07 PM
JoshRambo
Jul 30, 2005 05:46 AM
ImporttRacerr555
Dec 6, 2003 10:02 PM
Short_Shifter
Feb 6, 2002 01:31 PM
