raising comprssion?
Old Oct 24, 2003 | 01:45 PM
rusted_eyes's Avatar
Default raising comprssion?
I am planning on getting some EF-1 cams, but I was also wanting to raise the compression. What is the best way to go about doing this?
Thanks
Charles
Old Oct 24, 2003 | 02:23 PM
HKJ's Avatar
HKJ
Default Re: raising comprssion? (RdCivicSi)
you can buy high compression pistons, mill the head, or/and use a thinner head gasket from my knoledge.
Old Oct 24, 2003 | 06:45 PM
quikyEG's Avatar
Default Re: raising comprssion? (HKJ)
yup, high compression pistons is the best way........im not a fan of the thin head gasket thing....just get your head milled a bit and use an oem gasket.........my .02cents
Old Oct 25, 2003 | 02:59 PM
Thanks
Old Oct 25, 2003 | 06:51 PM
infinatenexus's Avatar
you could mill the head, run a thinner head gasket, and valves designed to raise your compression
Old Oct 25, 2003 | 06:54 PM
-KangaRod-'s Avatar
valves is a good way that is often forgotten about. You could have your combustion chambers welded, but I don't recommend that either. The best way I believe is with higher compression pistons. As long as the dome isn't much taller than a CTR it doesn't effect the flame front too much.
vajdmeg
Jan 30, 2009 11:01 AM
ls_bitik
Aug 9, 2007 08:22 AM
99b18
13
Mar 9, 2004 03:56 PM
fredtoast
Feb 16, 2004 10:25 AM
Blade_Irl
11
Mar 16, 2003 05:04 PM
