VAFC ODB2 Myth... fact or fiction?
Old Oct 24, 2003 | 12:59 PM
ITR981002's Avatar
Default VAFC ODB2 Myth... fact or fiction?
If I install a VAFC and tune my car, will the ODBII ECU compensate for the changes and set the fuel back to where it was before I started?
Edit: I did do a search and found a lot of people arguing about this, but no clear answer.
Old Oct 24, 2003 | 01:50 PM
Eva01's Avatar
Default Re: VAFC ODB2 Myth... fact or fiction? (ITR981002)
I've never heard of that myth...Alot of people have success tuning OBDII cars with a VAFC including me.
Old Oct 24, 2003 | 01:52 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: VAFC ODB2 Myth... fact or fiction? (Eva01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eva01 &raquo;</TD></TR><TR><TD CLASS="quote">I've never heard of that myth...Alot of people have success tuning OBDII cars with a VAFC including me. </TD></TR></TABLE>
No problems when I had mine.
Now the Pig on the other hand, if I adjust the base wastegate setting, the ECU will see the extra boost as a vacuum leak and adjust itself
Old Oct 24, 2003 | 02:14 PM
Rdriver's Avatar
Default Re: VAFC ODB2 Myth... fact or fiction? (Splat)
I have heard this myth as well. I was told that you had to reset your ecu on a regular basis to beat obd2. To me this seems to be an unreliable fix. Why not run a p28, with the vafc?
Old Oct 24, 2003 | 03:03 PM
CPR's Avatar
CPR
Default Re: VAFC ODB2 Myth... fact or fiction? (Rdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rdriver &raquo;</TD></TR><TR><TD CLASS="quote">I have heard this myth as well. I was told that you had to reset your ecu on a regular basis to beat obd2. To me this seems to be an unreliable fix. Why not run a p28, with the vafc?</TD></TR></TABLE>
From my understanding, even if you run a P28, that won't avoid the ECU from compensating the changes you made since it still runs in closed loop. The real solution is to run an ECU that's permanently open loop.
Old Oct 24, 2003 | 03:56 PM
IGGY's Avatar
Default Re: VAFC ODB2 Myth... fact or fiction? (CPR)
I have had my VAFC for a while and i have not had any problem. If the car's ecu recompensates for the changes i will be able to hear VTEC again!
Old Oct 24, 2003 | 06:30 PM
ultimatehonda's Avatar
I have only heard this happens for the preludes...I think your ok on b series engines.
Old Oct 24, 2003 | 07:33 PM
jetydosa's Avatar
25 Year Member
Default Re: VAFC ODB2 Myth... fact or fiction? (ultimatehonda)
I think this is only for Preludes as well.
Old Oct 25, 2003 | 05:48 AM
B18CXr's Avatar
on partial throttle, yes the factory ECU will adjust short and long term fuel trims to try and acheive ideal A/F but @ WOT, no.
Old Oct 25, 2003 | 07:19 AM
senpai's Avatar
Default Re: (B18CXr)
If that were the case, then all the boosted VAFC 'hack' users will be **** out of luck ... I've used it, and it's fine. The only people having problems are the ones who installed it wrong, or have no real idea of what they're doing
Old Oct 26, 2003 | 09:02 AM
ITR981002's Avatar
Default Re: VAFC ODB2 Myth... fact or fiction? (Jetydosa)
Awesome, thank you!
Old Oct 26, 2003 | 10:28 PM
Renegade's Avatar
I had problems tunning the fuel wit the VAFC, currently going to OBD1. No amtter what adjustments were made with the VAFC the A/F did not change. I put up a post about it, I'll try to find it.
Old Oct 26, 2003 | 10:32 PM
Renegade's Avatar
Default Re: VAFC ODB2 Myth... fact or fiction? (Renegade)
https://honda-tech.com/zerothread?id=438323
Old Jun 13, 2004 | 04:13 PM
itr1244's Avatar
so. OBD2 2001 ITR's ECU can be used with VAFC?
Old Jun 13, 2004 | 11:04 PM
jdmspoonitr's Avatar
Default Re: VAFC ODB2 Myth... fact or fiction? (itr1244)
Yes it works on my car too. 2001
Old Jun 14, 2004 | 05:57 PM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">so. OBD2 2001 ITR's ECU can be used with VAFC?
</TD></TR></TABLE>yes
ci_v_ic
11
Aug 5, 2006 12:40 PM
RAB
Feb 7, 2005 10:35 AM
itr1244
Jun 15, 2004 01:04 PM
Red D Dragon
May 23, 2004 05:42 PM
tommy b
Jul 22, 2003 06:21 AM
