Power Door Lock Rewiring...
Old Sep 4, 2001 | 12:00 PM
indy's Avatar
Default Power Door Lock Rewiring...
How easy is it to reroute the wiring for the power door locks to the center near the E-Brake?
Indy
Old Sep 5, 2001 | 05:55 AM
BlackAckeR's Avatar
Default Re: Power Door Lock Rewiring... (indy)
ttt.
Good question; I'd like to know the same!... I have already replaced my inside door handle panels with ones from an RS, and hidden the power switches behind them. But I really miss this feature, and moving that functionality to the center console sounds like a very good (and secure) idea!
Anyone done this?
Old Sep 6, 2001 | 05:42 PM
indy's Avatar
Default Re: Power Door Lock Rewiring... (BlackAckeR)
seems like we are in the same situation unfortunately no one seems to know how to do it!!!!!!!!!!
RS door handles look SWEET though!!!!
Indy
Old Sep 6, 2001 | 09:42 PM
t's Avatar
t
It is really easy, all you need is 3 wires; a chasis ground,wire connected to lock trigger wire, wire connected to unlock trigger wire. These wires are located at the drivers kick panel area, behind the cruise control module. It should be in the grey connector.
blk/white-lock blk/red-unlock.
BTW, if you have an alarm installed with power locks, look for the splices that the installer made at that location (assuming he got the wires from that location)
Old Sep 7, 2001 | 06:14 AM
BlackAckeR's Avatar
Default Re: Power Door Lock Rewiring... (t)
thanks, t, I knew somebody would have the answer!... I didn't want to go through the hassle of popping the door panel and running more wires into the door; but I didn't think about them being in the kick panel!
Now, where to find a nice 2 pole momentary rocker switch to fit the center console...
Old Sep 7, 2001 | 07:45 PM
indy's Avatar
awesome that sounds pretty easy. THanks T.
BlackAcker, if you can find nice buttons let me know, for now I will prolly
use the power door locks till I find a suitable replacement.
Indy
ejoner
Audio / Security / Video
Oct 21, 2007 04:36 PM
Andrewm224
Oct 21, 2005 07:33 PM
spunky424
Mar 2, 2004 04:10 PM
Airbag Club
Oct 8, 2002 02:08 AM
