Do you recommend Bypassing throttle body Coolant lines?
Old Sep 4, 2001 | 11:15 AM
Meateater's Avatar
New User
Default Do you recommend Bypassing throttle body Coolant lines?
I just found something on vtec.net that involves bypassing the coolant lines that run through the throttle body. It says its supposed to free up a few horse power.. Does anyone have any experience about this? How much horsepower does it free up? What are the side effects of this? I live in california where it is relatively warm year round.
Thanks
Old Sep 4, 2001 | 11:18 AM
Honda318dx's Avatar
Default Re: Do you recommend Bypassing throttle body Coolant lines? (Meateater)
If it is warm all the time then do it.. But even when it was hot in VA, my would still have a surging idle..
Old Sep 4, 2001 | 01:40 PM
JG Luder's Avatar
Default Re: Do you recommend Bypassing throttle body Coolant lines? (Honda318dx)
don't do it, not worth the trouble it is to do it, or worth the trouble it causes.
Old Sep 4, 2001 | 01:56 PM
apexii's Avatar
Default Re: Do you recommend Bypassing throttle body Coolant lines? (JG Luder)
ditto that...
Old Sep 4, 2001 | 03:33 PM
G's Avatar
G
For those of you who had done the TB bypass, to relieve the surging you must block the FIV with some form-a-gasket material to prevent it from letting air through and having eratic idling. You can even remove the FIV completely, put a plate and the gasket material in-between and bolt it on......
Old Sep 4, 2001 | 05:52 PM
migo's Avatar
New User
Default Re: Do you recommend Bypassing throttle body Coolant lines? (G)
Exactly what I was going to say.
Old Sep 4, 2001 | 05:54 PM
DR's Avatar
DR
Can you give us some pictures or a diagram of what you are talking about?
Old Sep 5, 2001 | 06:20 PM
DR's Avatar
DR
What is the FIV? I really want to get rid of this surging!!!
Lith ium
Mar 7, 2017 09:58 AM
si_motor_spt
16
Oct 14, 2007 04:57 PM
jgrogan
Jul 14, 2007 07:56 PM
4DRmafia
Sep 3, 2005 10:17 AM
Propulsion
Jun 7, 2002 09:50 AM
