I FINISHED BOOSTING MY TEG...NEED HELP!
Old Oct 24, 2003 | 07:23 AM
OVERBOOST TEG's Avatar
Default I FINISHED BOOSTING MY TEG...NEED HELP!
I HAVE A 91 TEG..INSTALLED A96 LS MOTOR T3-T4 GARRETT TURBO, TUBONETICS WASTE GATE, TURBO XS BLOW OFF VALVE,AFC II, RC INJECTORS,EXAUST , INTERCOOLER AND A ACT 3RD STAGE CLUTCH,ALSO A FAL COOLING FAN..... THE CAR.. RUNS LIKE A DREAM ON 8PSI..
HERE IS MY PROBLEM.....THE COOLING FAN IS BRAND NEW SO IT WORKS. IF I TEST IT ...BUT WHEN I CONNECT IT TO THE OLD FAN CONNECTION IT DOES NOT KICK IN WHEN ITS SUPPOSE TO SO MY CAR OVER HEATS IF IM STOPPED AT A LIGHT ...MY CLOCK, HEAT..DONT WORK ...THE DOOR LLIGHT FLICKERS ...LIKE WHEN YOU HAVE BLOWN THE FUSE FOR YOUR RADIO...BUT THE RADIO FUSE IS NOT BLOWN.....IF I GROUND THE FAN ANYWHERE ELSE IT STAYS ON FOREVER..ARE ALL OF THESE PROBLEMS RELATED????..PLEASE HELP
THIS IS WHAT THE CAR LOOKED LIKE BEFORE I BOOSTED IT....I WILL UPDATE THE PICTURES TOMMORROW....EXTERIOR WILL BE DONE AFTER THE WINTER.....
STAY TUNNED...AND THANK YOU FOR YOUR HELP!
FOR MY PICS.. HTTP://WWW.SMOOTH-EFFECTS.COM
Modified by OVERBOOST TEG at 4:40 PM 10/24/2003
Modified by OVERBOOST TEG at 4:52 PM 10/24/2003
Modified by OVERBOOST TEG at 5:02 PM 10/24/2003
Old Oct 24, 2003 | 08:09 AM
DUCK COMMANDER's Avatar
Default Re: I FINISHED BOOSTING MY TEG...NEED HELP! (OVERBOOST TEG)
sounds like you have 2 problems.
#1 your caps lock key is stuck. you might be able to fix this easily with a simple tap on the key board. Maybe you need a new one.
#2 sonds like a loose ground probally installing that afc you knocked something loose or something. just go over everthing and make sure its tight
Old Oct 24, 2003 | 08:46 AM
andlude's Avatar
Default Re: I FINISHED BOOSTING MY TEG...NEED HELP! (DUCK COMMANDER)
whoa is that a 4 door second gen integra?? i always said if i had extrra money i would make one of those sick fast. sweet car, i cant wait to see the updated pics
Old Oct 24, 2003 | 09:14 AM
Default Re: I FINISHED BOOSTING MY TEG...NEED HELP! (andlude)
ITS VERY FAST RIGHT NOW...THE WAY IT IS....I HAVE TO TUNE IT STILL ...ITS RUNNING A LITTLE RICH .....I DONT KNOW WHO MUCH HP IM RUNNING...BUT IT PULLS!
MY FRIEND HAS A 98 MAXIMA W/ A VORTEC SUPERCHARGER...ALL DONE UP RUNNING MAX BOOST....AND HE SAID IT PULLS MORE THAN HIS CAR....I WILL ALSO UPDATE YOU W/ MY DYNO SHEET...
Old Oct 24, 2003 | 09:17 AM
Kazz's Avatar
maybe its the tempurate sensor that is by the theromostat. when my was bad my fan never can on either
Old Oct 24, 2003 | 09:29 AM
da9JDMls's Avatar
Default Re: I FINISHED BOOSTING MY TEG...NEED HELP! (JuuKe_EM)
you said you have a GS integra... in the fourth picture is clearly states LS beside where it says INTEGRA... expain please...
Old Oct 24, 2003 | 10:03 AM
Default Re: I FINISHED BOOSTING MY TEG...NEED HELP! (da9JDMls)
I REFER TO MY TEG AS A GS....BECAUSE I SWAPPED A 96 GS MOTOR W/ 10K ON IT.......WITH MY CAR NOTHING IS WHAT IT SEEMS.....YOU CANT SEE ANY GAUGES OR INTERCOOLER STICKING OUT...NO ONE WOULD KNOW MY CAR IS BOOSTED ...IF I DIDNT TELL THEM ...OR PASS THEM BOOSTING... WHEN IM DONE W/ THE CAR ITS GOING TO HAVE GSR LEATHER SEATS..ITS ALSO GOING TO HAVE A TITANIUM METALIC PAINT JOB......WHICH NO FACTORY LS OR GS WOULD HAVE.....SO MABE YOUR RIGHT....IF I HAD A CHOICE I'D CALL MY TEG..CONFUSED
" MY TEG FOUND IT'S MOJO"
Old Oct 24, 2003 | 11:32 AM
tb_pimpjuice's Avatar
If I had a choice I'd call you a moron, stop typing in all caps. This isn't AOL n00b chat.
Old Oct 24, 2003 | 01:01 PM
91tegrals's Avatar
wats the big deal about typing with the caps on does it make a **** cause everyone else seems care
Old Oct 24, 2003 | 01:11 PM
Default Re: (91tegrals)
because its annoying to read just like its annoyingwhenppldontusetheirspacebar or when they dont use puncuation or when their post isnt broken down into paragraphs and its one huge run on sentence and this one time at band camp
Seriously, how hard is it to just turn off caps lock, use comma's and periods, or hit the enter key to make your post more readable.
Old Oct 24, 2003 | 01:36 PM
non-VTEC's Avatar
Default Re: (tb_pimpjuice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tb_pimpjuice &raquo;</TD></TR><TR><TD CLASS="quote">because its annoying to read just like its annoyingwhenppldontusetheirspacebar or when they dont use puncuation or when their post isnt broken down into paragraphs and its one huge run on sentence and this one time at band camp
Seriously, how hard is it to just turn off caps lock, use comma's and periods, or hit the enter key to make your post more readable.</TD></TR></TABLE>
Old Oct 24, 2003 | 01:51 PM
xrocket21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tegrals &raquo;</TD></TR><TR><TD CLASS="quote">wats the big deal about typing with the caps on does it make a **** cause everyone else seems care</TD></TR></TABLE>
its like somebody is yelling at you, its obnoxious.
Old Oct 24, 2003 | 02:13 PM
thrty8street's Avatar
no bull stop using caps. good job on yo car, got any pics? got any quarter mile times?
bionichicken
Aug 1, 2012 09:04 PM
impalarod
Jul 8, 2008 05:07 AM
2Cleezy
Sep 2, 2005 08:48 AM
Nos4R2
Jan 26, 2003 09:40 PM
