compression test results
did a compression test the other day. i wanna know what ideal numbers would be for a d16z6. i got 180 across + or - 3 psi. whats a new engines numbers? thanks
*edit* it has 128k on it and it wasnt warmed up.
those are great numbers. i don't know what stock is, but i definately agree that +/- 3 is good stuff. especially for a motor with 128k =o)
my C5 did 209, 210, 212, and 211 from 1 to 4.
numbers are good- variation between cylinders is practially nothing. i think that u are supposed to have done it on a engine thats warm, but im not sure how much of a deal that is. for reference, i tested my z6 with 130,000 and i got 210,208,205,210. a little on the high side, but the variation wasnt bad at all.
i dont know how to do a leakdown! any one know the #'s from a brand new engine? im wondering cuz im going turbo some time this winter or if my engine sucks id swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGRhatch »</TD></TR><TR><TD CLASS="quote">where did you do the comp. test at???
bump for ya
i did it at my house, in my driveway.
bump for ya
</TD></TR></TABLE>i did it at my house, in my driveway.
cool i see i thought maybe you had taken it to a shop...
anyways yeah im thinking about doing mine tomorrow same motor... gotta run down to sears and buy the guage though.
the motor was previously turbo'd so i have no clue what numbers will pop up.
compression for Z6 should be 185 +- 25 i do believe. the 185 is for sure though. Mine were 185 +- 2 psi. Sounds like you're good to go for turbo project. Goodluck with it....
air temps below 50 F and cold motor.......155-160 psi
air temps at 65-70 F and cold motor........165-170 psi
engine at temp (165-170 water temp.......175-180 psi
If you got 180 psi on a cold motor, healthy!!!!!!
hondacrx2
Sep 1, 2010 02:33 PM
Belarus
Apr 2, 2010 03:01 AM
Dr. Gonzo
Mar 3, 2002 09:30 AM
