I hit the rev limiter today
Old Sep 4, 2001 | 10:03 AM
Apexi007's Avatar
New User
Default I hit the rev limiter today
This is the first time I ever hit the rev limiter, and it sounds horrible!!!
The engine made two high pitch reving noise, the tad was at 8200 +
Is this harmful to the engine?
And how often do you guys hit the limiter?
Old Sep 4, 2001 | 10:28 AM
Gabe's Avatar
Default Re: I hit the rev limiter today (Apexi007)
I do it every once in a while. It's not harmful (unless you do it for 5 minutes in one gear) but it should not make any noises. Tach should read around 8200 but it is very inaccurate. Actual fuel cut is 7700 rpms.
Gabe
Old Sep 4, 2001 | 10:57 AM
prelude1897's Avatar
Just don't leave it there. If you do it every once and awhile, it won't harm it.
Old Sep 4, 2001 | 11:19 AM
Honda318dx's Avatar
Calm down Happens all the time.. Its gonna be ok..
Old Sep 4, 2001 | 11:20 AM
4doorH22's Avatar
Did you miss a shift?
I'd imagine the high pitched reving noises you heard was the fuel cut doing it's job twice (with that tach needle bouncing off 8,100) while you were still at wide open throttle.
Old Sep 4, 2001 | 01:36 PM
Apexi007's Avatar
New User
Default Re: I hit the rev limiter today (4doorH22)
yeah, I think it actually did the job twice.
it sounds like this "vrooommmmmm, and then suddenly vroomm, vroommmmm", right before I let off the throttle
I felt quite stupid afterwards, how could I forget to shift?
[Modified by Apexi007, 10:37 PM 9/4/2001]
Old Sep 6, 2001 | 09:07 AM
LudeBehavior's Avatar
New User
I used to autocross my lil baby. I hit it alot, yeah it sounds bad but it's alright thats why it's there to stop you from hurting your ride.
Old Sep 6, 2001 | 12:04 PM
bullet9925's Avatar
New User
Default Re: I hit the rev limiter today (LudeBehavior)
your stock tach is off 200 rpm. or so says my fields vtec controller
Old Sep 6, 2001 | 01:24 PM
spyder's Avatar
New User
It's not that bad for your engine if you aren't running any kind of forced induction or anything. If you hit the rev limiter while under boost from a turbo, supercharger or N2O, then you've got BIG problems . When that happens, detonation really lives up to its name!
[Modified by spyder, 4:24 PM 9/6/2001]
93egSIboi
35
Dec 16, 2004 01:34 PM
htludernewbie
Aug 25, 2002 03:06 AM
PiYoImuT
Jun 29, 2001 10:57 AM
R-Rated
Jun 22, 2001 01:11 PM
Dr_pooface
Jun 18, 2001 01:58 PM
