Need help... what fuse location number is the radio fuse on a 98 GSR...
Old Oct 23, 2003 | 11:01 PM
Del Sol SiR's Avatar
Default Need help... what fuse location number is the radio fuse on a 98 GSR...
Old Oct 23, 2003 | 11:20 PM
thaiphob's Avatar
Nikon!!!
Default Re: Need help... what fuse location number is the radio fuse on a 98 GSR... (DelSolSiR)
just pull your fuse cover and whola! your gonna find it!
Old Oct 23, 2003 | 11:21 PM
cheezthis's Avatar
I think it's also in your owner's manual too? Shouldn't be tough to find...and if it's blown, it should easy to find even without a diagram. Just look for the blown fuse...
Old Oct 24, 2003 | 03:43 AM
Gerhard_001's Avatar
When you pull off the fuse cover it will have 'all' of your fuses listed and what slot they go in, on the inside of the fuse cover. Just flip the fuse cover around when you take it off, viola.
Old Oct 24, 2003 | 03:37 PM
Maybe you guys would make that mistake of not looking under the cover, but I've got more common sense than that. The transparent plastic diagram is missing, so no identification is on the cover. True, I can pull every single fuse out, but what if its one of the empty fuse slots that I need to put the fuse in ? that is why I need to know the fuse position, as there are numbers on the fuse panel. I don't have the owners manual, that is why I am asking... So please if you don't have an answer to my question, don't answer at all, just to add to your post score...
"Would a real Honda/Acura-Tech step up..."
NACvicSi
Aug 27, 2009 05:03 PM
piggydog
Jan 5, 2007 07:50 PM
crazyc@SRTmotorsports
Apr 20, 2006 03:48 PM
tuan...
Aug 7, 2004 05:47 AM
