preparing engine.
Old Oct 23, 2003 | 09:59 PM
Origin's Avatar
Default preparing engine.
okay i got my engine in the other day and while its still out i wanted to go ahead and switch some stuff out on it. i was wondering what i could use off my old engine as far as hoses (i assume all of them) and other things that might be there that i just don't know about quite yet. tomorrow or the next day i plan on buying some spark plugs, spark plug wires, rotor, timing belt, water pump, and tensioner pulley. i was assuming i could buy most of this at the local autozone, but if someone knows where i can get most of this stuff off the net that would be cool too. also, if there is anything else that i would need that wasn't mentioned let me know (exluding engine oils and fluids).
also, i saw a post about checking the internals of your engine first. just to check out everything looks normal. what exactly should i look at? thanks for anyones time.
Old Oct 24, 2003 | 06:14 AM
Origin's Avatar
Default Re: preparing engine. (Origin)
bump.
Old Oct 24, 2003 | 11:25 AM
Origin's Avatar
bump again..
Old Oct 24, 2003 | 11:27 AM
CroSi's Avatar
I recommend using all new hoses.
Old Oct 24, 2003 | 12:01 PM
Scarface928's Avatar
From: Northern Virginia home of missing hondas, USA
what engine do you have and what car is it going into?None,well almost all,of the d series will not work with any b-series
Old Oct 26, 2003 | 03:31 PM
Origin's Avatar
Default Re: preparing engine. (Scarface928)
its an 88 crx hf and im putting in a b16 xsi integra motor.
Old Oct 26, 2003 | 04:23 PM
mattb16a1civic's Avatar
I would suggest front and rear main seals,oil pan and valve cover gasket, could prevent alot of headaches, the lower rad. hose is a 91 teg hose the upper, well I used the one from the donor clip. dont forget mounts, axles, hubs, wiring, etc.... all of your old heater hoses will work just fine.
Old Oct 27, 2003 | 09:17 AM
Origin's Avatar
Default Re: (mattb16a1civic)
yeah i got mounts, and the swap came with axles and im working on learning about the wiring. thanks.
Old Oct 27, 2003 | 01:42 PM
if you want hte easy way out you can order a wiring setup from hasport, also what axles did it come with
Old Oct 28, 2003 | 09:44 PM
Origin's Avatar
it came with the integra's axles. steveo from hmotorsonline.com said they would work fine with the proper hubs from the si/dx.
Old Oct 28, 2003 | 11:29 PM
davens's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattb16a1civic &raquo;</TD></TR><TR><TD CLASS="quote">I would suggest front and rear main seals,oil pan and valve cover gasket, could prevent alot of headaches...</TD></TR></TABLE>
Bingo. Do front and rear main seals now while it's easy to get to. Both seals should be less then $15 and it's major insurance. Otherwise, if they start leaking, you have to remove the transmission to get to one end and do the equivalent of a timing belt swap on the other end.
Also look at cam seals.
justvisiting
Aug 9, 2009 08:27 PM
pdpjr
Oct 8, 2008 07:06 PM
ludewithanh22
Aug 24, 2004 08:19 AM
partsisparts
Jul 7, 2004 08:19 AM
SleeprCrx
Jun 25, 2003 01:04 AM
