Honda S2000 Honda S2000
motor specs on 04? compression?
Old Oct 23, 2003 | 07:20 PM
mugensport9's Avatar
Default motor specs on 04? compression?
what are the motor specs on the 04 s2k compared to the older ones.
ive heard that they have alot of boost problems in the past. i know the older ones have a 9K redline
the new motor has an 8K and a 2.4L motor i believe. i was just wondering if the compression was lower on these motors also.
id like to see how the rear end and tranny react to boost on these new s2ks.
im just curious, if someone can inform me it will be very apreciated.
Old Oct 23, 2003 | 07:37 PM
Civicboy's Avatar
Default Re: motor specs on 04? compression? (mugensport9)
All your questions can be answered at http://www.s2ki.com and it's a 2.2L.
Old Oct 23, 2003 | 08:38 PM
Default Re: motor specs on 04? compression? (Civicboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicboy &raquo;</TD></TR><TR><TD CLASS="quote">All your questions can be answered at http://www.s2ki.com and it's a 2.2L. </TD></TR></TABLE>
the site is pretty laggy.
but im sure i could get info there id just rather someone tell me here.
Old Oct 23, 2003 | 10:31 PM
CLOUT's Avatar
same hp: 240 ...a little more torque 161. more usuable powerband. 11.1:1 compression. 87.0 x 90.7 bore and stroke. 2.2 liters
turbo s2000's were pretty reliable motor wise-many in the high 200whp(280290) range without tuning or lack of(vafc).
it's the diff's that were the problem if the car was driven real hard(clutch dump's/drag racing)
Modified by GDPzS2000 at 11:02 AM 10/25/2003
Old Oct 24, 2003 | 10:48 AM
exhaust_note's Avatar
u mean 161 lb.ft torque...
Old Oct 24, 2003 | 01:45 PM
Civicboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugensport9 &raquo;</TD></TR><TR><TD CLASS="quote">
but im sure i could get info there id just rather someone tell me here.</TD></TR></TABLE>
yah it has been slow, sorry
Old Oct 24, 2003 | 10:42 PM
hey thanx alot everyone
Old Oct 25, 2003 | 02:02 AM
CLOUT's Avatar
Default Re: (exhaust_note)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exhaust_note &raquo;</TD></TR><TR><TD CLASS="quote">u mean 161 lb.ft torque...</TD></TR></TABLE>
ya-
Old Oct 26, 2003 | 10:23 AM
gsracer170's Avatar
Default Re: (GDPzS2000)
do you guys think the toda cams can still be used w/ the 04 head?
Old Oct 26, 2003 | 01:29 PM
Razor's Avatar
Default Re: (maingear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maingear &raquo;</TD></TR><TR><TD CLASS="quote">do you guys think the toda cams can still be used w/ the 04 head?</TD></TR></TABLE>
im pretty sure its ok. the only changes(i think) are in the block, they stroked the engine. oh yeah, higher compression pistons.
Old Oct 29, 2003 | 06:04 AM
unvmyS's Avatar
Default Re: (Razor)
it's actually 163 torque, not 161...
Old Oct 29, 2003 | 07:26 AM
CLOUT's Avatar
Default Re: (S2Kvisions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2Kvisions &raquo;</TD></TR><TR><TD CLASS="quote">it's actually 163 torque, not 161...</TD></TR></TABLE>
nice catch
Old Oct 29, 2003 | 02:41 PM
crxONcrack's Avatar
so on the 04's, everything under the hood should be the same??? does anyone know if the air ducts and exhausts and so on and so forth from 00-03 can be installed on the newbies????
Coltmorris
Dec 12, 2006 04:27 PM
ceasar of mgineering
Jul 9, 2005 05:17 PM
Avenged7x
May 18, 2005 07:15 AM
1.8
Jan 30, 2005 06:11 PM
X2BOARD
Apr 29, 2002 04:53 AM
