HELP! Foglights wont turn on anymore!
Old Oct 23, 2003 | 05:57 PM
EM1Guru's Avatar
Default HELP! Foglights wont turn on anymore!
i tried doing the fog light trick on my 00 si. i swapped the wires that were stated here: http://forums.clubsi.com/showf...art=1
the fog lights did not turn on, but the other lights did.
i rewired them the way they were originally, still no workie.
i replaced the foglight fuse, still no workie.
i dont know what else is wrong. any help is appreciated.
thanks!
Old Oct 23, 2003 | 08:11 PM
EM1Guru's Avatar
Default Re: HELP! Foglights wont turn on anymore! (EM1Guru)
bump
Old Oct 23, 2003 | 08:28 PM
pennies_hatchie's Avatar
try hooking the straight up to the battery to see if they still work, if they do, then you're doing something else wrong
Old Oct 23, 2003 | 08:31 PM
blackhatchy's Avatar
Default Re: HELP! Foglights wont turn on anymore! (pennies_hatchie)
maybe the bulbs are blown?
Old Oct 23, 2003 | 08:32 PM
EM1Guru's Avatar
Default Re: HELP! Foglights wont turn on anymore! (blackhatchy)
as of right now, the only thing i can think of is that the bulbs are blown, or i have a bad relay.
another thing i shouldve added is, that my green light in my switch wont light up anymore.
Old Oct 23, 2003 | 08:46 PM
vtekthis's Avatar
could be a bad switch. if the light on the switch no workie problem is the the switch no workie. connect them srtaight to the battery to see if the lights even work.
Old Oct 23, 2003 | 08:49 PM
EM1Guru's Avatar
Default Re: (vtekthis)
i dont know how to tap them straight to the battery
Old Oct 23, 2003 | 08:51 PM
zelifcam's Avatar
check fuse
OE fog light wiring diagram possibly here if you need it:
http://www.honda.co.uk/owner/workshopmanuals2.html
Old Oct 23, 2003 | 08:53 PM
EM1Guru's Avatar
Default Re: HELP! Foglights wont turn on anymore! (zelifcam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zelifcam &raquo;</TD></TR><TR><TD CLASS="quote">check fuse
http://www.honda.co.uk/owner/workshopmanuals2.html</TD></TR></TABLE>
fuse has been replaced.
thanks for the link
Old Oct 23, 2003 | 10:12 PM
FcUK It.'s Avatar
probably isn't grounded right, or you have a blown-out fuse, light bulb is burned out, defective relay, or it doesn't have power. check your wiring again too, if one wire is not connected, the whole thing wont work. try hooking up the power wire to the battery too as said above
Old Oct 23, 2003 | 10:23 PM
eg ferio's Avatar
could be the switch or not properly grounded....try running them to your parking lots,thats how i have mine cuz my fog switch kept blowing the fuse
Old Oct 24, 2003 | 06:57 AM
vtekthis's Avatar
take the neg and pos directly from the foglight and touch the terminals on the battery
WhiteNeko
Oct 22, 2012 01:53 PM
egjake
Jan 20, 2009 02:37 PM
rugimpy
11
Nov 7, 2008 01:54 PM
amit_b82
10
Mar 2, 2008 08:39 PM
99delsol
Sep 14, 2006 08:01 PM
