car only goes to redline at night on the interstate
Old Oct 23, 2003 | 05:12 PM
NeverEnough's Avatar
Default car only goes to redline at night on the interstate
I can not rev past 6200 unless im on the interstate at night with the heat on. During the day ive never been able to get it past 6200 no matter what i try. I have plenty of coolent and replaced the thermosat but still same problem. My temp gauge sits just below the half way mark. I was told that if the car does not warm up past 190 it wont rev past 6200, but with the heat on it should run cooler yet it works when the heat is on at night but it does not during the day. Outside temp during the day is 75 at night about 55. I have taken it to a honda/acura only shop and they dont have a clue. Thank you for reading any help is appreciated.
car is a 95 ex with a greddy turbo kit
ryan
Old Oct 23, 2003 | 05:14 PM
mycivicstoo(s)low's Avatar
Default Re: car only goes to redline at night on the interstate (NeverEnough)
Check your oil level.
Old Oct 23, 2003 | 05:46 PM
Default Re: car only goes to redline at night on the interstate (mycivicstoo(s)low)
oil level is good, vtec also works fine
Old Oct 23, 2003 | 05:54 PM
slim-tim's Avatar
mabe ur throttle isn't opening enough. . . .lol that sux
Old Oct 23, 2003 | 06:05 PM
Default Re: (slim-tim)
Headgasket? I don't know man, that's a weird problem.
Old Oct 23, 2003 | 06:11 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (mycivicstoo(s)low)
EDIT: after rereading the original post, I had nothing constructive to offer.
Old Oct 23, 2003 | 06:12 PM
Rhythm Racer's Avatar
i would say check your throttle cable .maybe its loose and its not opening it up all the way!! thats weird
Old Oct 23, 2003 | 06:15 PM
sohcvtec1995's Avatar
Default Re: (Rhythm Racer)
do you have the missing link for your turbo? and dose your check engine light come on?
Old Oct 23, 2003 | 06:52 PM
Ricey McRicerton's Avatar
Default Re: (sohcvtec1995)
What engine management are you using??
Old Oct 23, 2003 | 07:06 PM
im using the fcu which comes with the 92-95 greddy turbo kit, no check engine light, a missing link is not needed when using the fcu i think it hides the boost from the ecu.
Old Oct 23, 2003 | 07:09 PM
Andres-eh2's Avatar
fcu or fmu?
Old Oct 23, 2003 | 07:29 PM
Default Re: (EGEESIX)
come to think of it i dont remember, most people refer to it as the blue box, it just runs rich at like above half throttle, none of the settings can be changed hth.
and also thanks for all the quick responces
mirza
Honda Civic (2001 - 2005)
Mar 12, 2007 11:44 PM
CivicGSRsi
Dec 9, 2006 12:33 PM
MysteryWagon
Mar 27, 2003 09:37 PM
rivvin
Mar 22, 2003 01:04 AM
