Sanding before final coat of paint... what grit? wet or dry?
Old Oct 23, 2003 | 04:00 PM
JDubya's Avatar
Default Sanding before final coat of paint... what grit? wet or dry?
Well i'm almost done painting my LS Mesh wheels. But before i do the final coats, i want to sand down the previous coats a little to smooth them out. What grit should i use for this? and should i wet sand? or just do it dry? if you say wet, why? and how is it done exactly? Thanks
Old Oct 24, 2003 | 04:16 AM
JDubya's Avatar
Default Re: Sanding before final coat of paint... what grit? wet or dry? (ALL MOTOR LS)
bump
Old Oct 24, 2003 | 08:49 AM
JDubya's Avatar
bump cuz i wanna do this, like now.
Old Oct 24, 2003 | 08:57 AM
Reza.dc's Avatar
i would try 2000 grit. if you are skilled with the spraycan, you wont need to sand.
Old Oct 24, 2003 | 08:59 AM
JDubya's Avatar
Default Re: Sanding before final coat of paint... what grit? wet or dry? (reza)
This was my first time painting anything big, like wheels. No parts are messed up, they actually look pretty good. It's just some spots are a little smoother than others. For final coats, should i do them heavy or light?
94 accord typeR
Aug 2, 2014 06:49 PM
ghosthatch
Paint and Body
Nov 23, 2012 08:01 PM
chinoty
Apr 25, 2008 07:17 PM
S2kGuy07
Honda S2000
14
Jun 12, 2007 12:34 PM
mrnewguy
Aug 19, 2006 10:36 AM
