brake noise or suspension?
Recently my driver side front brake or somthing in the suspension is making a creaking noise when coming to a stop and upon accleration, i checked everything that has a bolt and nothing is loose, any ideas?
Push down on your car and if you hear the noise then its suspension, if you dont heat it then its brakes and just change the pads.
Dont be to worried about the suspension its probably just a shock going bad. I had a bad shock for a good while now, just save up and get a good suspension set up.
I have something like that. Mine does it only when I stop. It creaks real loud. Everthing looks good. I've taken it apart twice. tommorow I think I'm going to replace my pad retaining clips. (I think that's what they are called). I'm pretty sure this is the problem. maybe this will help you.
