Grinding 2nd gear
Old Oct 23, 2003 | 01:38 PM
markv's Avatar
Default Grinding 2nd gear
I installed my short shifter a while ago and 2nd gear has been grinding occasionally. anyone have any idea what is up? or how to get it fixed? thanks.
Old Oct 23, 2003 | 01:49 PM
SCedGSR's Avatar
Do you ever grind gears? Could have just been a coincidence and a syncro is going out.
Old Oct 23, 2003 | 01:55 PM
markv's Avatar
Default Re: (SCedGSR)
i'm almost 100% sure that it never happened before i installed it or atleast i never noticed it.
Old Oct 23, 2003 | 01:59 PM
Mr Type R's Avatar
Default Re: Grinding 2nd gear (markv)
I believe your syncro is going out because my car does the same for 3rd gear. You will need a new tranny to get rid of it. dont even waist your time and money getting it fixed.
Old Oct 23, 2003 | 02:03 PM
Hybrid Invasion's Avatar
Default Re: Grinding 2nd gear (Mr Type R)
before going out and spending a lot of money on a new tranny, please check the fluid level in your tranny; if it's too low, it'll grind and occasionally pop out of gear. That's what mine did, and the 2 tranny places I took it to never even bothered checking the fluid level to let me know it was too low. Changed my tranny fluid, used GM Synchromesh Friction Modified, and now I have absolutely no grinds, and it doesn't pop out of gear at all.
Old Oct 23, 2003 | 02:11 PM
markv's Avatar
good idea
i'll check fluid to make sure.
Old Oct 23, 2003 | 02:54 PM
integ 1983's Avatar
along with the tranny fluid check your clutch fluid resevoir. if its running low fill it up with some dot 3 or dot 4 fluid you can get at an auto store. recently happend to me 2.
Old Oct 23, 2003 | 03:09 PM
Default Re: (integ 1983)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integ 1983 &raquo;</TD></TR><TR><TD CLASS="quote">along with the tranny fluid check your clutch fluid resevoir. if its running low fill it up with some dot 3 or dot 4 fluid you can get at an auto store. recently happend to me 2.</TD></TR></TABLE>um.....on a cable tranny?
Old Oct 23, 2003 | 03:23 PM
markv's Avatar
oh ya
i have a cable = no fluid..
Old Oct 25, 2003 | 03:40 PM
markv's Avatar
up
deejae
Nov 16, 2013 02:39 PM
ekmaniac101
Jun 17, 2008 08:15 PM
JDM-EJ698
Sep 1, 2006 03:26 PM
elevatethis
41
Nov 24, 2003 12:02 AM
crxtreme27
Aug 19, 2002 02:11 PM
