Chain Lube???
Old Oct 23, 2003 | 01:12 PM
TurboSam's Avatar
Default Chain Lube???
what does everyone use to lube their chain?? i have heard silkolene and honda silicone spray. i thought about using some gear oil on it like we use on some of our heavy equipment chain.
TIA
Old Oct 23, 2003 | 03:01 PM
StageOne's Avatar
Default Re: Chain Lube??? (Turbo Sam)
I only use Honda chain lube as it is safe for chains with o-rings. You may want to see if the gear oil will have any adverse affects.
Old Oct 23, 2003 | 05:10 PM
big pete's Avatar
Default Re: Chain Lube??? (StageOne)
I use the Bel Ray Super Clean chain lube. It doesnt fling off or attract dirt
Old Oct 23, 2003 | 07:07 PM
markymarc's Avatar
Default Re: Chain Lube??? (big pete)
stuff called "Chain Wax"
Old Oct 24, 2003 | 04:35 AM
Nikki_rider's Avatar
wd-40. it is cheap and works even if some say it could be harmful.
Old Oct 24, 2003 | 06:30 AM
slylos's Avatar
Default Re: Chain Lube??? (markymarc)
I use "Chain Wax" as well, its great . . . It doesn't fling and get all over your bike like oil would or anything like that . . . but you gotta let it dry for like 5 minutes after you spray it . . .
Old Oct 24, 2003 | 08:02 AM
figment's Avatar
New User
Default Re: Chain Lube??? (slylos)
Honda pro chain lube:
Does not require chain to be hot, not a wax so it does not discolor, (you can see how dirty the chain realy is) works pretty good.
Old Oct 24, 2003 | 08:14 PM
Ag-Eng's Avatar
Default Re: Chain Lube??? (figment)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by figment &raquo;</TD></TR><TR><TD CLASS="quote">Honda pro chain lube:
Does not require chain to be hot, not a wax so it does not discolor, (you can see how dirty the chain realy is) works pretty good.</TD></TR></TABLE>
Yep, that's what I use.....
Cleaning the chain = Kerosene & a clean rag.
Old Oct 25, 2003 | 06:28 AM
rapid_roy's Avatar
Default Re: Chain Lube??? (Nikki_rider)
It also flies off, it's to light. I wouldn't recommend that.
Cheers,
Roy
Old Oct 28, 2003 | 07:02 PM
big pete's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikki_rider &raquo;</TD></TR><TR><TD CLASS="quote">wd-40. it is cheap and works even if some say it could be harmful.</TD></TR></TABLE>
I wouldnt use wd-40...it messes up the o-rings
Old Oct 28, 2003 | 11:07 PM
ShiftStain
Guest
Posts: n/a
chain wax for my r6
Old Oct 29, 2003 | 05:52 AM
todaCspec's Avatar
Does anyone actually clean their chain before using lube or wax? I've spoken to a few different parts guys and they told me they never clean it, they just wax it . I asked about using Kerosene for cleaning, they looked at me as if i was crazy. Has anyone tried using Belair, i think that' what it was called?
Old Oct 29, 2003 | 09:29 AM
hondaZvic's Avatar
Default Re: Chain Lube??? (todaCspec)
how often does the chain need to be lubed?
Old Oct 29, 2003 | 11:34 AM
rapid_roy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by todaCspec &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone actually clean their chain before using lube or wax? I've spoken to a few different parts guys and they told me they never clean it, they just wax it . I asked about using Kerosene for cleaning, they looked at me as if i was crazy. Has anyone tried using Belair, i think that' what it was called?</TD></TR></TABLE>
I clean it at the beginning of the year with Simple Green and then lube it once a month during the riding season or immediately after riding in the rain.
Cheers,
Roy
Old Oct 30, 2003 | 04:41 AM
baddassduramax's Avatar
Default Re: Chain Lube??? (rapid_roy)
i use PJ1
Old Oct 30, 2003 | 07:22 AM
slylos's Avatar
Default Re: Chain Lube??? (hondaZvic)
Since we're not affected by winter here in florida I lube my chain every 200 miles and clean like every 3 months . . .
Old Nov 1, 2003 | 04:42 PM
trutuner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big pete &raquo;</TD></TR><TR><TD CLASS="quote">I use the Bel Ray Super Clean chain lube. It doesnt fling off or attract dirt</TD></TR></TABLE>
this or maxima works good!...-Roger
Old Nov 2, 2003 | 11:43 AM
D16OnTop's Avatar
maxima is the best
namewasdallas
12
Mar 25, 2008 04:40 PM
gjsolo
12
May 16, 2005 10:53 PM
integrator43
Honda Motorcycles
17
Mar 10, 2005 01:03 AM
yellowturbo
Mar 22, 2004 06:32 AM
-BlueGSR-
May 25, 2003 03:40 PM
