Dyno of my latest Civic motor...
Old Oct 23, 2003 | 06:35 AM
b19coupe's Avatar
Default Dyno of my latest Civic motor...
After some difficulty documented here https://honda-tech.com/zerothread?id=641908 ) I got another engine built and tuned by Shawn Church-C_A_T on this board. It put down 166.3 ft-lbs of torque and 246.3 HP on Shawn's DynaPack through a stock ITR muffler. Then for kicks C_A_T put his "magic dyno intake" on the car and it picked up another 13 HP, the graph you see here:
Import Builders spec Wiseco pistons-Toda 'D's-GSR crank-ITR head ported by Portflow and combustion chambers welded by Joe Alaniz.
The car is still a "B19coupe" , barely at 1979cc's. Will have to change my username to B20coupe if I go to 86mm bore
Old Oct 23, 2003 | 06:40 AM
DevinW's Avatar
Beautiful! Good show...I bet that cost a pretty penny. What type of car is this engine in?
And what is this dyno intake you speak of? Open throttle body?
Old Oct 23, 2003 | 06:42 AM
Big Teggie's Avatar
Default Re: Dyno of my latest Civic motor... (b19coupe)
Very Impressive, Good Job
Old Oct 23, 2003 | 06:49 AM
AllMotorMark's Avatar
just curious why the torque curve is so spikey... wondering if it is just the dyno cause i have seen that before
nice power
Old Oct 23, 2003 | 06:56 AM
b19coupe's Avatar
Default Re: Dyno of my latest Civic motor... (T.O.STREETRACER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T.O.STREETRACER &raquo;</TD></TR><TR><TD CLASS="quote">just curious why the torque curve is so spikey... wondering if it is just the dyno cause i have seen that before
nice power </TD></TR></TABLE>
Torque curve is "spikey" due to the scale on the graph. "Normal" dyno charts usually go in increments of 10, rather than 2. The intake used was an ITR AEM CAI. It's cut off at about the distributor so that a filter can be run under the hood if it rains hard-that's where C_A_T hooked his "magic" intake up. The magic intake is just a straight piece of 3" tube aluminum flared like a trumpet at the end. It moved the intake hump up about 500 rpm.
Old Oct 23, 2003 | 07:09 AM
smnowell's Avatar
damn, real nice numbers Using a velocity stack in your intake made that much more power? I have to say, I am quite impressed with that dyno chart!
Old Oct 23, 2003 | 08:16 AM
igotyofire's Avatar
Default Re: Dyno of my latest Civic motor... (b16a ferio)
umm what kinda gas is this running on? obviously where in cali so just wondering
Old Oct 23, 2003 | 08:42 AM
b19coupe's Avatar
Default Re: Dyno of my latest Civic motor... (igotyofire)
Running on 100 octane "cool blue" from Union 76.
Used2beAb16's Avatar
and any reason why u didnt "dump" the muffler, even just once to see how much power you WOULD pick up w/o it? Of course being tuned for teh muffler isn't gonna let u show the max gain of being tuned w/o a muffler, But im curious how much power is to be had w open exhaust on a 13.5:1 motor.
Old Oct 23, 2003 | 08:46 AM
Suprdave's Avatar
What's this equate to on a Dyno-jet?
Suprdave
Old Oct 23, 2003 | 08:47 AM
b19coupe's Avatar
Default Re: Dyno of my latest Civic motor... (Used2beAb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Used2beAb16 &raquo;</TD></TR><TR><TD CLASS="quote">and any reason why u didnt "dump" the muffler </TD></TR></TABLE>
C_A_T has neighbors, so he can only tune open header during certain hours. Due to scheduling restrictions (mine,his) yesterday was really the only time he could give me the 2-3 hours necessary to fully tune the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">What's this equate to on a Dyno-jet?
Suprdave</TD></TR></TABLE>
Around 230-240 on a DynoJet.
Old Oct 23, 2003 | 09:57 AM
C_A_T's Avatar
This motor has a lot more power in it. The initial results (246 hp) were about what I would have expected, maybe a little better considering the muffler.
But when we put the intake on the gains were much bigger than I've seen before. That tells me that the car is corked up on the intake side, and probably on the exhaust side too. I would expect something closer to 270-275 fully freed up.
And usually you can subtract 10-15 hp to equate Dynapack to Dynojet results, but there are other variables involved such as ramp time and wheel weight. The lighter the wheels, the closer the results will be.
C_A_T
Old Oct 23, 2003 | 10:01 AM
C_A_T's Avatar
BTW, I was surprised at how well this car idled. I said as much to B19coupe. If any of you want tips on getting massive cams (Toda D's in this case) to idle cleanly, drop him a line - I didn't have to do any work on that aspect.
C_A_T
Old Oct 23, 2003 | 10:10 AM
vtecvoodoo's Avatar
Future Texas Boy
Very Impressive.
Old Oct 23, 2003 | 10:20 AM
CHEETAH's Avatar
very nice, glad all worked out, when will you run the car ? keep us posted.
Greg
Old Oct 23, 2003 | 10:22 AM
speedyonez's Avatar
Damn... i need a tunner.. looks like my motor..
Old Oct 23, 2003 | 10:27 AM
specie's Avatar
Very nice.
What header was used?
Old Oct 23, 2003 | 11:18 AM
owen_the_soyboy's Avatar
Default Re: Dyno of my latest Civic motor... (specie)
sick power
Old Oct 23, 2003 | 11:41 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specie &raquo;</TD></TR><TR><TD CLASS="quote">What header was used? </TD></TR></TABLE>
HyTech big tube header. Looking to run the car at Pomona this weekend (open header). Now that the motor is putting down the kind of power that I was looking for, it's time to start playing with the chassis to get the 60's down. And as C_A_T pointed out, there is more power to be had from the motor. The motor is capable of flowing more- it just needs to be freed up some on the intake side.
Old Oct 23, 2003 | 01:23 PM
xJ.SLOTHx's Avatar
nice numbers...congrats
Old Oct 23, 2003 | 02:20 PM
jarel's Avatar
damn....very nice numbers
Can't wait to see your car run at Pomona this weekend
Old Oct 23, 2003 | 02:36 PM
Tbone's Avatar
Looks great man All the heavy hitter street cars are comming alive finally This is good motivation for me as well as christians motor.
Old Oct 23, 2003 | 02:40 PM
Viorent Grip! EG's Avatar
beautiful numbers.....
wow..
would really love to see results at the track
Old Oct 23, 2003 | 02:44 PM
MAX_CFM's Avatar
Nice
Old Oct 23, 2003 | 05:21 PM
Beave0101's Avatar
geeez, congrats on those numbers Todd! that power is insane!
