Should I use the LS crank in GSR???
Old Oct 23, 2003 | 04:27 AM
sircrxracer's Avatar
Default Should I use the LS crank in GSR???
Just wondering what benifits this would give me??? I'm building a drag CRX and want to use a GSR block with factory o/s CTR pistons. Just wondering is it worth the extra hassel so do a LS crank? I would like to put down like 200hp to the wheels think this is possible with some Skunk 2 stage 3's??? Thanks Rob
Old Oct 23, 2003 | 04:40 AM
TrboInteg's Avatar
Default Re: Should I use the LS crank in GSR??? (sircrxracer)
If you have ls rods and a crank laying around, I'd say go for it. I think I am as soon as I get a crank. If you have to tear down your motor anyway to put new pistons in you might as well up the displacement to.
Also, you may want to use that search function that Honda-Tech has provided for you. I can remember seeing several treads on this a few months ago and there was a lot of good info in them.
jksmith
Nov 3, 2008 11:14 AM
CIVICSI12
Sep 19, 2006 06:02 PM
Slink2000
Mar 20, 2006 08:50 AM
88hondahatch
Jul 15, 2003 07:03 AM
JUNcr-x
Apr 3, 2003 07:11 AM
