what offset te37 in 15" will fit ITR with spoon calipers
?as title states
what offset and what width 15"te37 will fit 5x114.3 ITR with spoon calipers without using spacers
+43 and +38 for certain, there might be others. Ask BlackR as mentioned, and thanks to Ken for keeping up a list of these.
+45 will require a 2 to 3 mm spacer.
Ironically, stock ITR wheels fit with the Spoon Calipers fine.
I only know this because I have the +45's and was also curious.
It maybe different, my AusDM OEM rims need a 3mm spacer. So what off set we need for the TE37 15x6.5 rims?? Thanks
.....+43 wouldn't work for me (15x7).
They still needed spacers.
I'd recommend +35. I dunno what offets they come in though..... And width will affect fitment to a certain degree..... Also, remember that wheels do bend a little under high G forces - and as close as the +35's might clear while sitting on the car, at speed around a high speed/ high G corner, you might actually cause the wheel to rub the caliper.....
I think a thread by user GiFF has a list of wheels..... (linked in the previous post).
I'm using racing hart cp035's in 15x7.5, +40 offset with MUCH success. TONS of room. The 15x7's would probably work as well, but wider is better imho.....
If I was to go with te37's, I'd go with 15x8.....
They still needed spacers.I'd recommend +35. I dunno what offets they come in though..... And width will affect fitment to a certain degree..... Also, remember that wheels do bend a little under high G forces - and as close as the +35's might clear while sitting on the car, at speed around a high speed/ high G corner, you might actually cause the wheel to rub the caliper.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">+43 wouldn't work for me (15x7).
They still needed spacers.</TD></TR></TABLE>
+3mm spacer did the trick for me with those wheels, not a problem.
They still needed spacers.</TD></TR></TABLE>+3mm spacer did the trick for me with those wheels, not a problem.
Todd00
Nov 15, 2007 10:07 AM
under_psi
Apr 28, 2003 02:20 PM
