Which ECU is best
Best for what application? I mean...if you are running a stock D16Z6 motor, I wouldn't really suggest using a P72 ECU. Likewise, if you are running a GSR or B16...the P28 wouldn't really be beneficial.... Also, lock your poll so you don't get the retarded "Smoke weed everyday" poll choice...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a ferio »</TD></TR><TR><TD CLASS="quote">...Also, lock your poll so you don't get the retarded "Smoke weed everyday" poll choice...</TD></TR></TABLE>
ooops...too late
ooops...too late
except for the p72 having a knock sensor, all of those ECU's are compatible with eachother code. (you can disable the knock sensor in the code anyway)... so its a wash
also you can add IAB to a p28/pr3/whatever you want real easy
you guys need to read pgmfi.org more
also you can add IAB to a p28/pr3/whatever you want real easyyou guys need to read pgmfi.org more
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a ferio »</TD></TR><TR><TD CLASS="quote">Best for what application? I mean...if you are running a stock D16Z6 motor, I wouldn't really suggest using a P72 ECU. Likewise, if you are running a GSR or B16...the P28 wouldn't really be beneficial...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGinNY »</TD></TR><TR><TD CLASS="quote">
what part of "they're all essentially the same" did we get lost at? its like any other computer, only does what you tell it to... and if you can do it with what you have why buy something else?
dkrex001
Oct 1, 2006 10:34 PM
thehondaguru
Nov 26, 2003 06:55 AM
