Problems with the car help!!!
Old Oct 22, 2003 | 07:26 PM
stilzx61's Avatar
Default Problems with the car help!!!
my driver side door handle is broken and when the window is rolled down the door wont close but when it is rolled up it does close...any ideas on whether its the window that needs to be replaced or is the door handle the sole problem?
also do any of you guys know how much a new hood latch will cost...i dont mean the latch on the hood but the one thats on the radiator support or whereever...thanks in advance!
Old Oct 22, 2003 | 10:29 PM
Spartanic's Avatar
Default Re: Problems with the car help!!! (stilzx61)
If you take the door panel off roll down your window you'll probably see that its binding aginst the door lock mechnisms and I'm pretty sure you'll figure out what needs replacing when you see it in action. You should check out Hondaautomotiveparts.com for the hood lock that you need.
makeitwork
Oct 15, 2012 07:37 AM
street_devils
Jul 21, 2008 05:31 PM
Promart
Aug 5, 2007 03:21 PM
danslee
Jun 30, 2004 03:42 PM
