oil filter part number...
Old Oct 22, 2003 | 04:15 PM
2000CX's Avatar
Default oil filter part number...
anyone have the honda part number for the oil filter for an 00 b16? are the part numbers the same for all b series like they are for all d series? thanks for anything you got
Old Oct 22, 2003 | 04:24 PM
dantastic's Avatar
Default Re: oil filter part number... (2000CX)
most hondas 86-00 use the same filter, except for the passport and insight
Old Oct 22, 2003 | 04:30 PM
2000CX's Avatar
Default Re: oil filter part number... (dantastic)
even from b series to d series? the filter they gave me looks way skinnier than the one on the block now. i was scared to take it off and try and fit it because my car would have been stuck at the garage where i do all my work. i lined it up on top of the one currently on the motor and it looked about a 1/8 inch on both sides too narrow...i felt it was a big difference.
Old Oct 22, 2003 | 04:34 PM
Frozen E's Avatar
H-T White Ops
I actually have one sitting right here in front of me still in the box. It's a Fram. PH3593A.
::Edit::
Ooops, didn't see that you wanted the honda #.
I say go with the Fram instead though. Get the one with the grip end on it. Makes oil changes VERY easy.
Old Oct 22, 2003 | 04:42 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Don't waste the $5 on the US FRAM filters, they suck.
Try a Purolator Pure One or Mobil1.
Old Oct 22, 2003 | 04:54 PM
2000CX's Avatar
Default Re: oil filter part number... (SkyeC)
is Mobil 1 as good as Honda? i always see people using Honda so i figured i would do the same.
Old Oct 22, 2003 | 05:04 PM
EL Vap133's Avatar
I have a 97 Teg, 97 Civic, 88 CRX with a B16 and they all use the same oil filter so I would assume they are all the same for D and B series motors...
Old Oct 22, 2003 | 05:05 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
do a search... there is nothing special about honda filters, especially the new smaller fram-built ones.
Old Oct 22, 2003 | 05:17 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC &raquo;</TD></TR><TR><TD CLASS="quote">do a search... there is nothing special about honda filters, especially the new smaller fram-built ones.
well the only thing special about oem filters is the anti flowback valve. regular frams DO NOT have it. however, fram tough guard and better filters do. i either use mobil1 or fram tough/double guard filters. that black coating on the end really does make it easy to take the filter off. i love how i can reach behind my intake manifold from the engine compartment and take the filter off
Old Oct 22, 2003 | 05:38 PM
ejprimo's Avatar
part number 15400-PCX-004 will get you the made in japan oem oil filter.
you got a smaller filter because they discontinued the large size oem filter in favor of the smaller newest civic and rsx oil filter. btw, the part number i listed is for a S2000 oil filter and its the same size as the discontinued large oem filters.
Old Oct 22, 2003 | 05:45 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: oil filter part number... (ejprimo)
Isn't the larger filter, now that it is S2000 only, $15?
Old Oct 22, 2003 | 05:55 PM
ejprimo's Avatar
i got it for $8.25 at the honda service center in torrance, ca and some guy said he found it for $6 but id like to know where he got it from.
Old Oct 22, 2003 | 10:27 PM
SamC's Avatar
i was quoted $8.25 as well...let me know if you guys find a cheaper place
Old Oct 22, 2003 | 11:46 PM
LSVTECoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejprimo &raquo;</TD></TR><TR><TD CLASS="quote">part number 15400-PCX-004 will get you the made in japan oem oil filter.
you got a smaller filter because they discontinued the large size oem filter in favor of the smaller newest civic and rsx oil filter. btw, the part number i listed is for a S2000 oil filter and its the same size as the discontinued large oem filters.</TD></TR></TABLE>
how is that filter listed above so much better than the one used now? just wondering....
Old Oct 23, 2003 | 08:50 AM
ejprimo's Avatar
Default Re: oil filter part number... (LSVTECoupe)
http://www.hparts.com sells 15400-PCX-004 for $5.89 each.
im not sure which oil filter is better but personally i like to use the larger filter made by honda as suppose to the smaller newer filter. they discontinued all the large size filters so that part number provided will get you the large size filter.
Old Oct 23, 2003 | 09:12 AM
hitvtecgetloud09's Avatar
wow funny never thought workin at ez lube(oil changing place) would come in handy ill get the filter number for u next time i go to work..moble 1 is the best btw. and use synthitec oil.
Old Oct 23, 2003 | 09:21 AM
GimpyAccord's Avatar
Default Re: oil filter part number... (hitvtecgetloud09)
Do the 1988 mitsubishi montero oil filters fit Civics like they do Accord/Ludes? Or is the oil sender too close to the filter for it to fit? I havn't tried yet as I just got my civic Obviously you pick the brand, its just normally for a Montero.
Modified by GimpyAccord at 10:57 AM 10/23/2003
Old Oct 23, 2003 | 09:55 AM
jolt-tsp's Avatar
Default Re: oil filter part number... (GimpyAccord)
I always used Mobil 1 until I saw the price, still get them for the S2k but the Civic just uses Fram Toughguard and get twice as many oil changes. Honda one isn't a bad idea though, right inbetween crappy and overkill =p
Old Oct 23, 2003 | 10:02 AM
pdiggitydogg's Avatar
hparts.com selling honda oil filters for $4 each...I guess honda is going with the new hamp filters for all the cars...clearance!
edit**oh and I only use the pure1 and honda filters...cheap and good
Old Oct 23, 2003 | 11:20 AM
SamC's Avatar
Default Re: (pdiggitydogg)
anyone know what is the part number for the crush washer (14mm)?
Old Oct 23, 2003 | 01:34 PM
2000CX's Avatar
Default Re: (SamC)
so the filter is smaller now... chalk that one up as my bad...you really do learn something new everyday.
Old Oct 23, 2003 | 01:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GimpyAccord &raquo;</TD></TR><TR><TD CLASS="quote">Do the 1988 mitsubishi montero oil filters fit Civics like they do Accord/Ludes? Or is the oil sender too close to the filter for it to fit? I havn't tried yet as I just got my civic Obviously you pick the brand, its just normally for a Montero.
Modified by GimpyAccord at 10:57 AM 10/23/2003</TD></TR></TABLE>
do any of you know? i did a search but nothing matching Montero in the EG+
guess I could always try, car need an oil change anyway.
Old Oct 24, 2003 | 06:39 AM
crush washer #
94109 14000 17187
.18 at hparts
Old Oct 24, 2003 | 06:42 AM
0psi's Avatar
One filter fits all Honda's from 84 and up, except the Hybrid, Insight and S2000. That part number is 154-PLM-A02.
acmoc
Dec 25, 2008 12:36 PM
philosofy1
12
Sep 29, 2005 06:24 AM
sloweh3
Jul 19, 2003 05:05 PM
MikeSarr_GSR
Dec 1, 2002 04:34 PM
PhxK20a3
Jun 10, 2002 06:07 PM
