What should I get for Rear Speakers in an Integra?
Old Oct 22, 2003 | 02:52 PM
integra-modder's Avatar
Default What should I get for Rear Speakers in an Integra?
I have 6.5" Alpine componenets up front and I am satisfied with their sound for the cost. I can either keep them there and get a less expensive set for the back or put them in the back and get a new set of comps up front.
Here are the choices:
SPR-174A Target Retail Price US $180.00/CN $299.00
6-1/2" Type-R Coaxial 2-Way Speaker
SPR-176A Target Retail Price US $250.00/CN $399.00
6-1/2" Type-R Component 2-Way Speaker
One is components, one is not. I will NOT be mounting the tweeters. The speakers run off of my Alpine MRV-F340 Amp. Its a 4 channel unit that puts out 55 watts at 4 ohm.
Please let me know what you think.
Old Oct 23, 2003 | 07:57 AM
4doorex's Avatar
Default Re: What should I get for Rear Speakers in an Integra? (integra-modder)
Between those two? I would buy the top ones for the rear and leave your seperates in the front. If you want to spend more money then put seperates in the rear too, though it's not necessary.
Other speakers I would choose Infinity kappas. I have yet to hear a better sounding set of seperates.
Matt
Old Oct 23, 2003 | 01:17 PM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Default Re: What should I get for Rear Speakers in an Integra? (4doorex)
Do the Type R componets have a coax mount? If so you can mount them in the rear with the tweeters. I don't think you will like the sound without the tweeters.
Old Oct 23, 2003 | 01:40 PM
TrblPinoy1's Avatar
I would disconnect the rear and not run them at all...run as much power to the front as possible.....
Old Oct 23, 2003 | 01:56 PM
Default Re: What should I get for Rear Speakers in an Integra? (arizsun21)
These are INFINITY Reference 6002si.
Here are the specs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Size 6-½"
RMS Power Range 2-50Watts
Peak Power Handling 150Watts
Sensitivity 92dB
Frequency Response 58-21KHz
Design 2-way
Tweeter Design Dome
Tweeter Composition Textile
Woofer Composition Polypropylene
Woofer Surround Rubber
Impedance (Ohms) 4
Dimensions
Top-mount Depth 1-7/8" </TD></TR></TABLE>
These are $72 shipped vs the Alpine's being $110 shipped.
Would they sound the same or should I get the Alpine's?
Old Oct 23, 2003 | 02:19 PM
ATF Kuk's Avatar
IMO those are one of the best sounding coax's. i can beat $72 shipped.
Old Oct 23, 2003 | 02:37 PM
stockLS's Avatar
Default Re: What should I get for Rear Speakers in an Integra? (ATF Kuk)
infinity makes a good componet set pick those up man!
Old Oct 23, 2003 | 02:57 PM
EBP_SI's Avatar
Default Re: What should I get for Rear Speakers in an Integra? (TrblPinoy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrblPinoy1 &raquo;</TD></TR><TR><TD CLASS="quote">I would disconnect the rear and not run them at all...run as much power to the front as possible.....</TD></TR></TABLE>
I agree...why not sell what you've got in there right now. Take the money you get for them and the money you had planned on spending on the new speakers and use that to buy a better set for the front.
I've had front speakers only in my civic for the past year and i dont think i'd ever go back.
Old Oct 23, 2003 | 04:07 PM
Default Re: What should I get for Rear Speakers in an Integra? (EBP_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">
I've had front speakers only in my civic for the past year and i dont think i'd ever go back.</TD></TR></TABLE>
im not that big of an audio freak....
i just want to get a crisp and clear sound without spending thousands
what is the benefit of having more power go up front and not having rears at all?
Old Oct 23, 2003 | 07:49 PM
Torridcivic's Avatar
I'm in the process of getting a new amp so I am only running my two fronts right now. CANT STAND IT. my stock system before was not time corrected, but my aftermarket system is and you can truely hear each individual speaker. It drives me crazy when I turn on the stereo and can't hear anything from the back, I would rather listen to nothing.
You want both front and back, balance = clarity
Type r's
Infinity perfects (more money)
Old Oct 23, 2003 | 08:51 PM
Default Re: What should I get for Rear Speakers in an Integra? (Torridcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Torridcivic &raquo;</TD></TR><TR><TD CLASS="quote">I'm in the process of getting a new amp so I am only running my two fronts right now. CANT STAND IT. my stock system before was not time corrected, but my aftermarket system is and you can truely hear each individual speaker. It drives me crazy when I turn on the stereo and can't hear anything from the back, I would rather listen to nothing.
Type r's
Infinity perfects (more money)</TD></TR></TABLE>
What do you think about these:
Kappa Series KAPPA62.5I 6-1/2" 2-way multielement loudspeaker pair
Kappa Series KAPPA63.5I 6-1/2" 3-way multielement loudspeaker pair
Do I need a 3 way in the back? Will a 2 way be good enough to get the job done?
Old Oct 24, 2003 | 08:12 AM
ArizSun21's Avatar
I had fronts only in my comp civic and I have to say rears add more depth to the sound. Besides if you have fronts and rears you can always just disconnect the rears
Old Oct 24, 2003 | 09:28 AM
Guys...what do you think....
One of these for the back:
$ 65 - Reference Series REF6002SI 6-1/2" Two-way shallow mount
$ 80 - Kappa Series KAPPA62.5I 6-1/2" 2-way multielement loudspeaker pair
$100 - Kappa Series KAPPA63.5I 6-1/2" 3-way multielement loudspeaker pair
$110 - Alpine SPR-174A 6-1/2" Type-R Coaxial 2-Way Speaker
Help me pic one and order it...
The 6002si is tempting because its just a slim design...
Old Oct 24, 2003 | 01:53 PM
Kappa series 2 way for the back. That is my suggestion.
Old Oct 24, 2003 | 04:00 PM
ArizSun21's Avatar
Alpine baby!!! Match front and rear speakers
Old Oct 25, 2003 | 01:27 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arizsun21 &raquo;</TD></TR><TR><TD CLASS="quote">Alpine baby!!! Match front and rear speakers</TD></TR></TABLE>
Yea...its pretty much between the alpines and the 6002si....
I like the fact that they are inexpensive/cheap and have a slim design...
Old Oct 25, 2003 | 01:37 AM
Import13alla's Avatar
The infinity reference loudspeakers are some of the best sounding mids that I have ever heard. I have a set of their 5 1/4's in my si and love them. Definately go with the 6002si's. For the price you can't beat them!
dhatb0ijohnny
Audio / Security / Video
15
Sep 1, 2007 03:00 PM
pjz99accord
Aug 19, 2006 08:48 AM
FOUR-G
Jul 20, 2004 05:52 PM
mr_mbuna
Sep 8, 2002 12:45 PM
frankoma
Jun 7, 2001 02:50 PM
